AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 19-09-2005, 10:53 PM   #1 (permalink)
geewhizz's Avatar
Thanks: Gave 71, Got 40
Exclamation .TS Files, Need Help
Just aquired Some HDTV files ( in the form of .ts )
Now when i play them on VLC player, they play fine but i cant hear any sound,
Could it be a codec problem, My sound card is working fine.
Or is it something else.
HD-DVD
DVD'S
geewhizz is offline
Old 20-09-2005, 8:54 AM   #2 (permalink)
Thanks: Gave 0, Got 21
Try rename them to .mpg and just play them in Windows Media Player. The problem in VLC could be the way you've got it set up. For example do you have an SPDIF output on your PC and have you set VLC to output over that?
Sparky101 is offline
Old 20-09-2005, 8:58 AM   #3 (permalink)
Thanks: Gave 8, Got 14
Try installing the elecard mpg player and codecs that should sort it.
evolution400 is offline
Old 20-09-2005, 11:41 AM   #4 (permalink)
geewhizz's Avatar
Cheers guys, will try it tonight..
HD-DVD
DVD'S
geewhizz is offline
Old 20-09-2005, 4:42 PM   #5 (permalink)
geewhizz's Avatar
That did the trick,
Thanks Mate.
HD-DVD
DVD'S
geewhizz is offline
files
Refbacks are On
Thread Thread Starter Forum Replies Last Post
.ts files pinky3003 High Definition TV Hardware 48 20-11-2007 2:35 AM
Guide : Backing up your DVDs to hard disk Stuart Wright Movie Suppliers and Technology 227 06-07-2006 8:44 PM
how to play multiple .ts files tim k High Definition TV Hardware 15 07-09-2005 12:13 PM
Adding DD 5.1 soundtrack to .ts files David167 High Definition TV Hardware 7 14-07-2004 1:17 PM
Coverting .ts files museumsteve High Definition TV Hardware 4 06-07-2004 12:04 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
