AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
Closed Thread
LinkBack Thread Tools Display Modes
Old 17-09-2005, 12:09 PM   #1 (permalink)
What newsgroup would you recommend?
What do you use and why?
lochindaal is offline
Old 18-09-2005, 12:30 AM   #2 (permalink)
Thanks: Gave 0, Got 21
For what? Give us a clue. Are you looking for a newsgroup provider or are you looking for a particular newsgroup??
Sparky101 is offline
Old 18-09-2005, 6:59 AM   #3 (permalink)
Thanks: Gave 32, Got 102
If you're looking for a provider then Newshosting has my vote. I've used many over the years and this is very cheap (about £8.50 pm) and the retention is 40 days which is blinding. No speed issues either and carries all groups. Well worth it.
emporer is online now
Old 18-09-2005, 7:14 AM   #4 (permalink)
Thanks: Gave 1, Got 2
I can second Newshosting
neil c is offline
Old 18-09-2005, 8:20 AM   #5 (permalink)
Thanks: Gave 0, Got 9
im with Giganews now, is newshosting worth the £5 saving a month?
ginoworm is offline
Old 18-09-2005, 8:51 AM   #6 (permalink)
Starburst's Avatar
Thanks: Gave 86, Got 625
In my time I have used both Giga and NH (currently using NH) simply down to the cheaper unlimited useage price but overall I think Giga had the edge but the difference now is so small it's not worth the extra money.
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline
Old 18-09-2005, 12:29 PM   #7 (permalink)
Thanks: Gave 0, Got 3
What download speeds is everyone getting? Im on a 3Gb NTL connection using Giganews and am getting 320 - 380 Kbs. Should I not be getting higher transfer rates?
Lobo is offline
Old 18-09-2005, 12:40 PM   #8 (permalink)
phillfyspoon's Avatar
Thanks: Gave 3, Got 61
no 360 is about max and it does go up and down. Newshosting is the best I have ever used and I have used a quite a few.
Speed 10/10 - for my 3mb anyway
retention 10/10 most big groups about 29 days
Completion 10/10 never had an incomplete file
cost 10/10 the best unlimited service for the service you get
phillfyspoon is offline
Old 18-09-2005, 12:54 PM   #9 (permalink)
tim k
Posts: n/a
A great combo is www.newzbin.com and usenetserver. newzbin allows you to just click on a particular d/l and it takes the message id (which inc.s all the necessary files) it then d/s in your reader (using grabit, which is amazing for speed) and its then just a case of unrarring, htdtv-mpeg conversion and if necessary quickpar.
Im with bulldog on a 8meg connection. getting average speeds of 550kbps d/ls on most hdtv sources (this is running 4 simultaneous files into the reader at max). This means i can have a full dvd size file in 3 hours. Or a .ts hdtv film in 6-8. I just have a browse on newzbin each morning before work and load it in. Then each night i can just unpack and clean it up and enjoy the HD movie on my 42" pd7200 and dd5.1 from the denon and kef 5005 combo. BLISS!! Something always to look forward to after work.
Some great movies to look out for at the moment - Ray 1080idd5.1, Gladiator bev 1080idts, the forgotten 1080idd5.1, spartan 1080idd5.1 lord of the rings hdtv, alias hdtv, bones hdtv, us open hdtv, longest yard dvd.
Old 18-09-2005, 6:11 PM   #10 (permalink)
Thanks: Gave 20, Got 121
It's a 3MB line not 3GB, around 360 is what you should be expecting.
On 8MB bulldog I hover around a fairly constant 867k/b sec which is as fast as I can get on my line (using newshosting).
dan1979 is offline
Old 18-09-2005, 7:36 PM   #11 (permalink)
Thanks: Gave 18, Got 5
If you're going to use a newsreader program I recommend Newsleecher.
nogimmix is offline
Old 19-09-2005, 1:59 AM   #12 (permalink)
Thanks: Gave 1, Got 1
Some info of US usenetproviders info Their european list is incomplete 'cause there are some good cheap dutch providers who support up to 10Mb (and are going to upgrade to 20Mb).
A cheap one Eweka
They are getting to 28 days retention on binaries groups.
U.K. info 0906 - 6046044 ( GBP 0.60 per minute )
Looks like they have their own connection to LINX(The London Internet Exchange).
Son of Shaft is offline
Old 19-09-2005, 2:16 AM   #13 (permalink)
Kramer's Avatar
Thanks: Gave 5, Got 31
No discussion of how or where to download, illegally, copyright material . I would have thought admin's sticky thread made this clear.
Closing this thread. Discussion of newsgroups etc. should be in the appropriate forum, namely, computer hardware &.....
Kramer
My personal opinions expressed here are not necessarily those of the AV Forums or other related websites, but you all know that
Kramer is offline
newsgroup, recommend
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
