AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 15-09-2005, 1:57 PM   #1 (permalink)
Thanks: Gave 0, Got 6
BBC HD Tests to continue
See
http://hugecgi.com/cgi-bin/ibc_daily...=22940&issue=6
Alan
Hellicopter is offline
Old 15-09-2005, 4:47 PM   #2 (permalink)
Thanks: Gave 6, Got 11
I cant get any sound,anyone else have this problem?While im here.Does HD1,or any of the HD loops broadcast DD 5.1, I cant pick it up if they do.
Sony1292, IscanHD+
mediamogul is offline
Old 15-09-2005, 6:19 PM   #3 (permalink)
I can't get any picture. Anyone got a definitive guide to getting it to work?
jamesrich is offline
Old 15-09-2005, 7:01 PM   #4 (permalink)
Thanks: Gave 6, Got 36
What are you using a STB like the quali or skystar 1/2 card for the pc ?
It's still on 11.480 but no sound
RecordablDVDfan is offline
Old 15-09-2005, 7:07 PM   #5 (permalink)
Skystar 1.
Old 15-09-2005, 7:11 PM   #6 (permalink)
Thanks: Gave 4, Got 27
Please forgive my ignorance but if i had the right receiver could i just unplug my sky box, plug the relevant receiver in, change the settings and be able to recieve this channel, I'm assuming that because its coming from a transponder colocated with sky, i wouldnt need to move the dish? Or do i need a special LNB and shaped dish?
bbdivo is online now
Old 15-09-2005, 8:27 PM   #7 (permalink)
Yes you would probably get the channel ok with just a 45cm sky dish and a receiver like the quali. So no need to move the dish. HD 1 and a few others probably will be at 28.2 soon also but only in MPEG 4 format I guess
THere really should be an FTV HD package setup starting with the 5 main channels. It's going to cost a fair bit anyway to buy a decent plasma and MPEG 4 receiver...
Any I correct in thinking no other HD receiver like the forthcoming mpeg4 quali will get the SKY HD stuff ?
Old 15-09-2005, 9:24 PM   #8 (permalink)
bayards's Avatar
Thanks: Gave 24, Got 17
AFAIK only the Thompson Sky+ HD box will be good for Sky as they will have encryption on their services - and Quali boxes will be outside that framework.
Until the real launch any MPEG4 receiver should pick up FTA services - but bear in mind they will also be using DVB-S2 so receiver should be capable of that too. I hope my Philips DSR 9005 will be in my mitts by October - if so I can take a peek at current Sky trailer on 28.2 and BBC HD tests....
H
bayards is offline
Old 15-09-2005, 9:44 PM   #9 (permalink)
Assured Advertiser
Piers's Avatar
Thanks: Gave 24, Got 145
I am getting the BBC high def tests here with a Quali receiver but without sound. The current Quali receiver doesn't do MPEG 4 so I don't fully understand the ibc article - are they saying that it is going to switch to MPEG 4?
Piers (Home Cinema Engineering Ltd.)
ISF and HAA calibration <-- Click for details
Train to be an ISF or HAA Calibrator <-- Click for details
Piers is offline
Old 16-09-2005, 6:10 PM   #10 (permalink)
bayards's Avatar
No - i think they will kep it with MPEG2 until they switch off at end of year. They can leave the MPEG4 stuff to Sky who are already beaming that out from 28 E ast as well.
H
bayards is offline
bbc, continue, tests
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
