AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 13-09-2005, 6:26 AM   #1 (permalink)
Thanks: Gave 2, Got 1
HD Connections
It would appear that most new hi-def ready screens only have one HDMI / DVI connection and that on the horizon there is a multitude of kit (DVD, Sky HD, HTPC, Xbox) which will need it. At the moment only hi-end Amp like the Yamaha rx-v4600 offer multiple HDMI inputs.
My question is - can you really tell the difference between HDMI / DVI and good quality component connections ?
If everyone is going to go HDMI how will it be possible to link all the kit together to get the best picture? Will it be possible to daisy chain HDMI devices like scart?
Any opinions / suggestions most welcome ...
robe1101 is offline
Old 13-09-2005, 6:41 AM   #2 (permalink)
AML
AML's Avatar
Thanks: Gave 80, Got 128
As far as I know there is little difference between component and HDMI. just one is analog and the other is digital.
The biggest difference is that HDMI will use HDCP which is a requirement for future products like Blu Ray and HD DVD.
This is why its a problem that most TVs still only have 1 hdmi. Im sure give time makers will start to add more than one. Toshibas new SED tvs promise to have more than one. Im sure all will follow suit.
Gear: Epson EMP-TW1000 (1080p), Onkyo 805,
PS3 @ 1080p. 360 @ 1080p
PC:Q6600 @ 3.0ghz, 8800GTX
AML is offline
Old 13-09-2005, 8:33 AM   #3 (permalink)
Thanks: Gave 14, Got 8
HDMI/DVI + HDCP = Picture and Sound
Componet = No Picture
If content provider so chosses
scarty16 is offline
Old 13-09-2005, 11:03 AM   #4 (permalink)
can HD be transmitted by VGA cabling..?
lordnoize is offline
Old 15-09-2005, 10:32 AM   #5 (permalink)
Thanks: Gave 13, Got 6
You could always buy a switcher. There are several on the market that offer 4 HDMI inputs with one HDMI/DVI output connection to your tv. Must admit though that it is both tedious and annoying that HDTV manufacturers continue to offer new ranges with only 1 HDMI input. These people are not stupid so there must be a reason for their continuing to do so when they know people are going to need more. JUst wish I knew what it was !!
Ian Ball is offline
Old 15-09-2005, 10:53 AM   #6 (permalink)
Thanks: Gave 6, Got 14
I can't understand why a manufacturer would design a HD tv and put only 1x HDMI socket on it. Anyone who uses one HDMI socket (for SkyHD for e.g.) will very likely to be the sort of person who will use HDDVD or Blu-ray and a PS3 or XBox. I make that 3 HDMI sockets at lease with none to spare. You could argue that we could use DVI as another HD digital socket and a component connection as a third. But what if Sky moviesHD and Blu-ray only work through HDMI due to the copyright issue? Surely PS3 will play BluRay DVDs? This may need to be connected via HDMI to take advantage of this feature.
The only possibility I can think of is that it costs to add these sockets now and when there are no HDMI devices available here other than standard def DVD players, manufactureres don't see the 'instant' selling point. That would be a very short-term-ist attitude though. I would definitely spend more on a TV with multiple inputs. In fact, I'm waiting for one...
jw250 is offline
Old 15-09-2005, 11:46 AM   #7 (permalink)
Thanks: Gave 4, Got 27
PS3 will play BDROM movies and like any other HDDVD or BlueRay player, to get the full HD picture, you'll need to plug it through HDMI - component will probably show you a 480p image maximum due to the lack HDCP. It's still not 100% if there will be a total lack of signal or if the HD resolution of the movie will just be displayed as 480p. Everyone seems to think the latter is correct.
There are also HDMI boxes, much like the SCART boxes, where you can plug lots of things, and it comes out from one. So, have 3 HDMI devices plugged into the box, and plug the box output to the HDTV. Only one works at the same time, and you will only ever need to watch one at any one time. Not sure what the cost for a box like this will be, but the SCART ones are fairly cheap, i expect price for the HDMI ones to drop very quickly as demand rises.
Toshiba already makes an HDTV sold in the UK with 2 HDMI sockets.
DanDT is offline
connections
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
