AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 21-09-2005, 1:01 PM   #31 (permalink)
thanks! I think I shall be buying this on payday
lordnoize is offline   Reply With Quote
Old 21-09-2005, 1:05 PM   #32 (permalink)
ehr
Originally Posted by lordnoize
that Cleardragon one seems too good to be true!! £559
Interface
SCART 1 : CVBS IN & RGB IN & TV OUT (EU) Full SCART
SCART 2 : CVBS In & Monitor out (EU) Half SCART
COMPOSITE 1 (USA) RCA
COMPOSITE 2 (USA) RCA
S_VIDEO Yes
DVD (Y/Pb/Pr,AUDIO L/R IN) Yes
PC In (15P D-SUB) Yes
PC Audio in DVI (HDCP) HDMI Yes
SPDIF(Optical) OUTPUT Yes
HDTV READY (480p, 576p, 720p, 1080i) Y/Pb/Pr, RGB, DVI, HDMI
It is a good set. you can see what people who bought it on eBay think here:
http://feedback.ebay.co.uk/ws/eBayIS...me=STRK:ME:UFS
All the items with code 5806046312 are this 26" stock.
ehr is offline   Reply With Quote
Old 21-09-2005, 3:55 PM   #33 (permalink)
Thanks: Gave 30, Got 107
Originally Posted by rogeralpine
...no, the XB360 doesn't need to scale because it's the source of the material and like a PC, the user can define the output - assuming the game supports the graphic mode that is.
So with games in 1080i, the Dell wouldn't need to scale the image. Therefore if you had the Samsung, or similar sized resolution panel, 720p would be the best default option in order to minimise the amount of scaling that is going on. (Or not as the case maybe if the panel is 1280 x 720)
I'll certainly be comparing closely games running in 720p against 1080i - seeing the Gamecube operate in both i and p, the latter may well be the best option (for me) on the XB360 even if there is a loss in resolution. As to which is best, I don't think we should go there?
Hmm, I'm confused then. As the 360 outputs 720p as standard according to their specifications, and is THEN downscaled for other resolutions, so I'm presuming it's upscaled for 1080i?
Hmm!
NackNack is offline   Reply With Quote
Old 21-09-2005, 4:42 PM   #34 (permalink)
Thanks: Gave 4, Got 27
Hmm!
It's still not been confirmed. The X360 will be out in little more than a month in the US and a month and a half in Europe/UK so we'll know by then.
DanDT is offline   Reply With Quote
Old 21-09-2005, 9:28 PM   #35 (permalink)
Thanks: Gave 3, Got 0
I'm making the assumption that because the specs say it has various video modes, as with the Xbox the user would therefore be able to select their choice of output. US NTSC Xbox's had a display option memu which allowed the used to select up to 1080i - I can't see why the XB360 would be any different - except this time including those options on the PAL unit as well (rather than us relying on importing or chipping)
So there is no scaling going on. If the user selects 1080i on the Xbox and the game supports it all well and good, if not, the game just auto selects the next best display option.
rogeralpine is offline   Reply With Quote
Old 21-09-2005, 10:18 PM   #36 (permalink)
It says it has those specifications, but they said themselves that it outputs in 720p natively (or whatever the term is) and is downscaled for lesser TVs and so on.
Old 22-09-2005, 12:11 AM   #37 (permalink)
Thanks: Gave 6, Got 38
Originally Posted by LFCRules
Unbeatable are in Administration. Have a search in the forums for it and you'll find a couple of threads about them
Andy
I see www.unbeatable.co.uk is now a price comparison site, shame
RecordablDVDfan is offline   Reply With Quote
Old 22-09-2005, 7:47 AM   #38 (permalink)
.....well if 720p is the minimum it would obviously have to scale to lesser TV's - with 1080i being a quoted output, either that will be a selectable user defined output or it will be selected automatically by the XB360 dependant upon what display it is connected to. Either way, the unit will output 1080i and this will either be scaled on 720p TV's or will not be selectable. I can't any form of automatic display detection method working tbh.
They probably talk about 720p more as it's the display output that likely to be used most.
£500
Refbacks are On
AV ForumsOptimised for Firefox.
