AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Video Electronics > High Definition TV Hardware
LinkBack Thread Tools Display Modes
Old 12-09-2005, 5:10 PM   #1 (permalink)
Thanks: Gave 11, Got 6
philips 37pf9830/10
found the specs for the new 37PF9830.will be purchasing one soon
http://www.p4c.philips.com/cgi-bin/d...LARGE_30_40_SU
machinehead is offline
Old 17-09-2005, 4:28 PM   #2 (permalink)
Smile philips 37p9830/10
Got mine yesterday, paying 30.000 Danish kroner.
It's a beauty, setup was simple, the sound much better than expected. Black is almost as black as on the CRT. Lots of details in shadows, and the test picture from one of the local channels is rock solid with beautiful colours.
Our 32 inch CRT looks så smallish compared to the 37" LCD...
The only thing annoying me, is that I can't get the remote control to work with my Nokia Mediamaster 9902S.
I almost bought a 32PF9986 in July, but then found som threads here dealing with the PF9830's. So I ended up waiting two and a half month, getting 37 instead of 32 and 9830 instead of 9986 - at the price they quoted for a 32PF9986 back in July. Strange, but a good investment in time!
Kind regards
Lars
larshoej is offline
Old 17-09-2005, 7:26 PM   #3 (permalink)
well done.will be getting mine soon.was considiring a sony v 40.i have my heart and my head set on a philips though.prices here in the uk are funny at the moment.last week £2300 this week £2600.will wait until the prices drop slightly
Old 17-09-2005, 7:33 PM   #4 (permalink)
Thanks: Gave 16, Got 280
How about posting this in the LCD forum, I think it'll be more relevant there
neilmcl is offline
Old 17-09-2005, 7:56 PM   #5 (permalink)
Thanks: Gave 107, Got 498
whats the point if it doesn't take 1080p inputs?
Does it have a deinterlacer onboard that would create proper 1080p internally from a suitably flagged 1080i source?
It does seem to me like some manufacturers are going off half-cocked, simply to entice the early adopter.
richard plumb is offline
Old 18-09-2005, 10:22 AM   #6 (permalink)
is it or is it not a high def tv?.
Old 18-09-2005, 4:08 PM   #7 (permalink)
Thanks: Gave 28, Got 31
Exactly how much 1080p source material is there likely to be available in the foreseeable future? Very little I would guess, unless you want to ponce around connecting your PC to your telly to watch the odd 3 minute 1080p movie trailer. 1080i compatibility will be fine I suspect for the vast majorityof us.
HeweyBoy101 is offline
Old 18-09-2005, 4:22 PM   #8 (permalink)
Starburst's Avatar
Thanks: Gave 86, Got 625
From broadcast sources vurtually zero however the format will be supported and I expect delievered via Blu-ray and Hd-DVD pre-recorded formats.
Long term 1920*1080 native res panels are the future and being able to accept 1080p will in turn become the norm and the price will eventually drop just like it has for the 720p native panels.
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline
Old 20-09-2005, 10:11 AM   #9 (permalink)
Thanks: Gave 1, Got 0
Hi Guys,
out of stock at the moment but seems to have dropped here..havent tried them though, so dont know if they are good or not. Either way, they are out of stock for a while..
http://www.internetdirect.co.uk/ecranplasma/id42282.htm
neiltaffy is offline
Old 20-09-2005, 2:54 PM   #10 (permalink)
It is but this forum is for general disussions of HD not model specific technical queries which should be kept in their own relevant technology forum. The OP didn't ask any HD specific question did he?
It's no big deal just can be a bit annoying sometimes or maybe I'm just being a bit picky
neilmcl is offline
Old 27-09-2005, 10:43 AM   #11 (permalink)
It is HD TV, and Canal Digital will start sending 1080i as soon as sat boxes have been approved. Also Viasat has the Europe 1080i channel.
Lars
larshoej is offline
37pf, philips
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
