Got a few recommendations for you to be honest, first of all, you don't need a cd player anymore. The days of a cd player producing the best sound possible are gone. Instead you can rip all of your cds to your computer losslessly and connect your computer (if it has a SPDIF connection (optical) to an external via a TOS Link. Alternatively you can connect to the dac via the usb if your computer does not have the mentioned connection.
The two most popular dacs are the beresford MK6/3 MK6/4 which are ideally connected via an optical, or the Beresford TC 7520 which does allow for a usb connection. Alternatively there is the much publicized Dac Magic, I have not heard the latter but the sound quality from the Beresford is just fantastic, in terms of depth, in terms of seperation of the various sounds/instruments and detail.
In terms of speakers, i would have recommended floorstanders but as you are going to be moving elsewhere, likely with less room than you have already, it's best to go with bookshelves. The thing to remember about bookshelves is they are only going to sound at their best on a sturdy pair of speaker stands. I would certainly recommend you demo them first, but the Monitor Audio BR2's have so much grunt, power, presence a very lively sound, with very good bass for smaller speakers and a very convincing soundstage.
As far as amps are concerned, I would look on ebay for either the NAD C352 or the C320 BEE, the first would be my preference but I am mindful of your budget. This is something which never does seem to be accepted but in my opinion you should purchase Chord Carnival Silver Screen cable and get it terminated, (banana plugs). You would be looking at 5.25 per metre for the cable and additional for the terminations, approximately 25.00. This does seem like a lot of money but by all means, you could opt for some cheap QED micro cable which is more like 1.50 per metre.
The advantage of terminating the speakers is that it saves the fiddly process of connecting them to the speaker and amp terminals and in addition, prevents frayed cable and more importantly stabbing yourself with the exposed speaker wire...it happens! lol.
So to clarify, Monitor Audio BR2's which cost 200.00 new or obviously less second hand.
Second hand Beresford MK6/3 (if you have an SPDIF connection or if you have a ps3) probably on ebay approximately 90.00 using this as reference
Beresford Media & Electronics
Dac Magic over 200.00
Beresford TC 7520 around the price of the Dac Magic
NAD C320 BEE approximately 100ish second hand or NAD C352 approximately 200.00 ish second hand.
Speaker Stands I used Atacama Nexus 6 which were fillable also
RCA Phono cables to connect from the dac to the amp
The total price will obviously depend if you go for second hand or not and what type of connection your pc will allow.
