| Re: How can i enhance my front speakers?
I suspect the quality of music playback is more related to your room and your amp than your speakers.
Yes, you want good cables and wires, but there is no need to spend a fortune on great cables and wire unless you have a correspondingly very expensive system to connect those great cables to.
First, for music, make sure your amp is set to 'Direct' or 'Pure' mode which by-passes all the audio processing needed for surround sound. That will give you the best quality pure music playback.
Next play with the position of the speakers. Your room may restrict where you can put them, that's very common for everyone. But cant or angle the speakers inward slightly to see if you get better sound in your normal seating position. Try moving the speakers outward toward the corners, or inward away from the side walls and see if you find a position for them that suits you better.
Next, how hard is your room? Lots of bare floors and walls? If so, you are probably getting too may reflections. You need to find a way to soften the room with rugs and curtains, etc....
Finally, make sure your amp is set up properly, though if it sounds OK with video, then you are probably very close.
Just a few suggestions.
Steve/bluewizard
