| Re: Vintage Bang & Olufsen
My parents had a complete set of stuff like this.
It was wedge shaped, veneered woord with black plastic panels. The buttons are all touch sensetive, and I think it included a double tape deck, radio and amp, pop up cd tray, and a turntable similar to the one you described. I thought it was futuristic stuff back in the 90's!
It had a liniar tracking arm and direct drive platter, but with a special exta arm next to it. This had a sensor on it which could be used to seek the track joins and therefore use previous/next tracks. Unfortunatly it jammed up a few minutes after trying to use it a few years back, and we couldn't find a way to fix it so it's in bit in the shed! It used special 9 pin din plugs to allow control from the master unit/amp.
I don't think the accompaning speakers could be that huge, maybe a foot or so tall. I was miuch smaller last time i ever saw them. I'm pretty sure everything else works.
It looks pretty much like the stuff in the picture above. I guess i'd like to know if it has any value either! I don't have any access to model numbers currenty as it's all set up at our holiday home and due to the stellar weather conditions i hven't been up there recently.
