Re: Sherwood Newcastle
Does your Sherwood receiver have SRS Circle Surround? I used to have the R-756 (I think), which did. Similar to Pro-logic in that it extracted surround from a stereo source input. Don't think it was as good as Prologic 2, but it was certainly better than bog standard prologic.
As for no sound sound:-
Check you've got your cables connected to the output on the TV and not the input.
Check which input on the Sherwood you going into. It'll be one of the video ones if I recall. And ensure that video input it selected.
Eitherway its only a basic amp and is a brand which doesn't have much second hand value. I only got £35 for mine and that took a while...
What are your current speakers? We'll need to know if they're worth keeping. It maybe an option to just get a better receiver to go with your existing speakers, rather than get a complete new setup.
Arfa
Royd Apex front, Royd Envoy as centre, Wharfedale Pacific Evo DFS rears, BK Monolith-DF sub, Exposure XXVRC, Rotel RSP-976 & RB-985, Rega Apollo, Sony BDP-S550, Arcam Alpha 8 tuner, Creek OBH 8SE, Thorens TD160 Super + Heed Orbit 2 + Linn Basik LV-X, Playstation 3 (60Gb), Sony Bravia 32V2000
