mains question- please help.
Old 01-09-2008, 9:41 PM   #1
4,535, Level: 15
Points: 4,535, Level: 15 Points: 4,535, Level: 15 Points: 4,535, Level: 15
Thanks: Gave 10, Got 5
I just went to plug my goldring dr 150 headphones into a beresford tc 7510 dac. I accidentally touched the tip (pinnacle) of the 3.5mm headphone jack against the top of the dac. A crackling noise can be heard through the phones when I do this. The dac was switched off at the time. I also tried the same thing with my rotel ra 04 amp. Again the amp was switched off. But again, the same cracking noise could be heard through the phones. I did try touching the jack against the PC (on) but there was dead silence. In sum, the rotel & beresford seem to be noisy.
Why?
I use an mk double gang unswitched socket and tacima mains filter / surge protector.
Thank you.
Old 02-09-2008, 8:23 AM   #2
Mark.Yudkin's Avatar
16,380, Level: 30
Points: 16,380, Level: 30 Points: 16,380, Level: 30 Points: 16,380, Level: 30
Activity: 33.7%
Activity: 33.7% Activity: 33.7% Activity: 33.7%
Thanks: Gave 33, Got 1,036
Re: mains question- please help.
I thought plugs in the UK were three-prong so that they can't be reversed and that basically all equipment needed earthing?
If any of the equipment has a plug that can be inserted either way, reverse all those that have a single gang power switch on the neutral side. You can tell this from the exhibition of the symptoms you described.
Otherwise I would suggest that you check that the live / neutral wires in the wall socket are correct. With earth on the top, live is on the right and neutral on the left.
Old 02-09-2008, 8:29 AM   #3
Alun's Avatar
8,068, Level: 21
Points: 8,068, Level: 21 Points: 8,068, Level: 21 Points: 8,068, Level: 21
Thanks: Gave 303, Got 259
It could just be a build up of static earthing itself through the amp, but you also need to bear in mind that headphones operate at a very, very low voltage compared to the mains, so any kind of leakage or induction would probably be enough to make the cones move.
Powered by
 Latest popular product prices
ION Profile LP USB
3 prices from
 £54.97 Click to show/hide the offers
ION Profile Express USB
1 price
ION Profile LP USB
3 prices from
1 price
ION Profile LP USB
3 prices from
1 price
TEAC CD-P1260 Black
1 price
 £129.34 Click to show/hide the offers
TEAC CD-P1260 Black
1 price
 Updated February 11th at 3:30am. Prices include delivery.
