AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 14-08-2008, 2:48 AM   #1 (permalink)
Question Sony MHC-GNX800 turns itself off
Hi.
Stereo won't start.
Power amp supply-rail fuses VAPORIZED - black with melted fuse wire all over the inside of the glass.(something went wrong there...)
Power amplifier module is an STK412-150
If you try to turn it on(with new fuses fitted), the new fuses DO NOT blow, but the whole amp shuts off the second you press the power-button - even the LCD backlight is off, and just the power button backlight works - alternating between green and red.(about 1-second duty-cycle red-green over and over till you pull out the power plug)
If I remove the PSU fuses to the power-amp, the system does start up fine, but naturally, without any sound.
I think the STK module is dead, but I would like another opinion.
Can't measure the PSU voltages to the power amp module on the DC side of the bridge, as I can't start the unit up to measure them, but there is juice on the AC secondary of the welding transformer that the unit uses!
There's not much in the way of electronics in the power amp module - a couple of bridges, the STK, some filter caps, couple of relays a handful of SMD and that's about it. I have removed both bridges and tested them - they are fine, so I am about to replace the STK amplifier module, but would like any other opinions...
Can anyone tell me what the red/green flashing light on the power-button means? Obviously it is trying to tell me there is some kind of fault, but perhaps the flash sequence is different for different things?
Multiplexer is offline
Old 15-08-2008, 6:09 AM   #2 (permalink)
Re: Sony MHC-GNX800 turns itself off
It was the STK.
Made an executive decision based on my knowledge, and replaced the STK.
Amp works fine now.
mhcgnx800, sony, turns
Refbacks are On
Thread Thread Starter Forum Replies Last Post
New Sky HD turns itself off... Hamie Sky HD 354 23-05-2008 8:50 PM
Sony Turns a Profit on Game Division! Q3 Earnings AJUK PS3 0 31-01-2008 1:54 PM
Sony HXD860 turns itself off - replacement advice BSDan DVD Recorders, Recording and Media 1 05-07-2007 2:12 PM
TV turns itself off ? RDS290176 LCD Televisions 3 19-07-2006 9:34 PM
Sony KP-51DS1U - turns off after an hour andyfoo Rear Projection Televisions 0 20-12-2005 7:02 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
