AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 12-08-2008, 4:01 PM   #1 (permalink)
Source update
My config is currently set as :
- room : 7m * 5m * 2.5m
- b&w 802d
- krell kav-2250 + kav-280p
- transparent ultra (speaker cables and single ended conn pre amp-amp)
- music : jazz, classic, reggae
- ps3 (source)
Could I get some advices in terms of cd player? I am looking for something that would price up to the krell sacd.
Also, could anyone tell if there is a difference between the krell dvd standard and the sacd in terms of cd player?
audio972 is offline
Old 13-08-2008, 9:59 AM   #2 (permalink)
conman's Avatar
Thanks: Gave 9, Got 26
Re: Source update
Might worth take a look at a DAC (decent one). It seems to be a key for producing quality analogue signal.
Judging from your set up, benchmark DAC1 (USB or Non) or similar range might be your starting point.
You can still use PS3 as transport. If you are not happy with the result, just add a CD transport.
ConMan??? Wdf
CONstuction MANagement (in short)
conman is offline
Old 13-08-2008, 12:44 PM   #3 (permalink)
Thanks: Gave 7, Got 76
Re: Source update
At your price point, go check out some of the Esoteric units.
SB+, Bel Canto Evo2i, Impulse Ta'us, Coherent system, audio technica and Zanash cables, Stillpoints. PS3 with PlayTV, Panasonic AE1000, Thule PR250B processor, Kef 3005 (rears) driven by a Kenwood 3020se.
Mr_Sukebe is offline
Old 14-08-2008, 6:38 AM   #4 (permalink)
Thanks: Gave 0, Got 5
Re: Source update
Which PS3 model do you have?
Have you tried SACD and CD playback on it?
The 7th Taylor is offline
Old 14-08-2008, 11:53 AM   #5 (permalink)
Re: Source update
Have the PS3 60Go with SACD functionnality, but the pre amp is wired with the standad AV cables provided, which doesn't really help.
Have you tried the enhanced cables?
audio972 is offline
Old 14-08-2008, 12:10 PM   #6 (permalink)
Re: Source update
Thanks ConMan. The DAC1 is indeed an interesting option.
Have you had a chance to listen to this combo ( PS3 , DAC1) before?
audio972 is offline
source, update
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Humax LU26-TD1 - EPG update and Firmware update? andyloc LCD Televisions 2 24-01-2008 10:22 PM
Computer Source V's Dedicated Source Major Dutch DVD Players (Standard Definition and Upscaling) 7 26-07-2006 7:50 AM
How do I know if a dvd is film-source or video-source ? Tonvanrijn DVD Players (Standard Definition and Upscaling) 11 04-03-2006 6:12 AM
Dashboard update this monday and COD2 update Tuesday! zAndy1 Xbox 360 3 28-01-2006 10:33 AM
Judder compairing PC source to Video Source Comer Computer Systems 3 23-02-2002 8:16 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
