Originally Posted by JPNorth
I am away to purchase one now. will let you know if this solves the problem.
As a newbie to all this I am confused about the cable type I should have chosen, I was of the belief that more and more people are using CAT5E UTP to make custom cables, could anybody advise something more suitable as I don't make the same mistake again.
Many thanks,
JP
You can use CAT5 cable for carrying A/V signals, but you really need baluns at each end to convert the signal into a balanced one, i.e. in the same way as a computer network signal is balanced. This then means that any interference is induced equally onto both wires of a twisted pair which then gets cancelled out.
The transformer I pointed you to is effectively the same as a balun, and with a portable piece of kit like an ipod which has no ground reference will make the signal path balanced. The other thing to mention is that you have to use the right wires within the CAT5.
There's no point in using blue and green for the left channel for example - you have to use say blue and blue/white as they are twisted together.
A screened cable will be better than UTP for rejecting any interference as long as the screen is connected to ground (earth).
regards
Brian
