AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 07-08-2008, 6:39 AM   #1 (permalink)
Thanks: Gave 45, Got 4
Linn Karik CD - power issues - any cheap cure?
I've had my Linn Karik/Numerik combo for many years now, supported by a Linn Kairn pre-amp and a Linn LK280 power amp. Currently auditioning a pair of Totem Arros (but that's the subject of another post)
The system had to be boxed up for a year as there was no space or room to set it up. I spent yesterday unboxing and cabling at our new house, and everthing sounded and appeared to be working fine, but then the Karik started to play up. Here are the symptoms:
  1. Stopped playing a CD, but green power light remained on - all buttons on panel frozen
  2. Cannot power on - power switch has no effect
  3. Pressing power on switch does nothing, but when powering off, the green power light comes on and then fades off immediately
Does this sound like a user replaceable fuse problem, or is his an expensive trip back to a Linn dealer?
Any help most apprecaited!
Up until the time it decided to play up, it sounded just great, and was a real treat after playing CDs on a Panasonic DVDR or Toshiba HD-DVD for the last year
Pioneer PDP-LX608D, Arcam AVR280, SkyHD, Toshiba HD-EP35, PS3, Panasonic DMR-EX85 & S-VHS NV-HS850, Pioneer LD CLD2950, PixelMagic MB200, B&W CDM-9NT (bi-amp) + B&W M-1 (x3), Linn Sizmik 12.45, Logitech Harmony 1000; Linn LP12/Ekos/Arkiv/Lingo - Linn Kairn - Linn 2250 - Linn LK280 - B&W683 (bi-amp)
notfes53 is offline   Reply With Quote
Old 07-08-2008, 11:10 AM   #2 (permalink)
Thanks: Gave 2, Got 12
Re: Linn Karik CD - power issues - any cheap cure?
Doesn't sound like a fuse problem to me, but does sound like a power supply one.
Best bet is probably a trip to your dealer, but the bad news is that Linn have now officially stopped supporting the Karik due to the difficulty in getting parts. On the upside, the difficult part to get is the laser assembly, not the power supply, so you might be able to pick up a cheap "for spares" karik on eBay and then just swap the PSU over, which shouldn't be very difficult.
AV: Philips 963SA - Snazio SZ1350 - Yamaha YSP-1000 - REL Quake - SkyHD - Panasonic 42PHD8 - Van Damme Red video cables
HiFi: Naim CD3.5 - Linn AV5103 - Linn AV5125x2 - Linn Kabers (aktiv) - Linn Black interconnects - Linn K400 speaker cable
rowlandhills is offline   Reply With Quote
Old 07-08-2008, 1:48 PM   #3 (permalink)
Thanks for that reply: maybe not what I wanted to hear, but probably realistic!
cheap, cure, issues, karik, linn, power
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Linn Karik CD gazza73 Hi Fi Systems and Separates 6 01-06-2007 11:29 AM
Dead Linn Karik 3 fontana Hi Fi Systems and Separates 2 08-09-2006 7:00 PM
Strange Linn Karik display behaviour chedmaster Hi Fi Systems and Separates 7 10-07-2005 6:02 PM
Proposed Linn UnidiskSC to VisionProHDP - Any foreseeable lip sync issues? Jackass Video Scalers, Video Processing and Progressive Scan 2 27-04-2004 11:15 PM
Someone cure my AV buying addiction! (and thoughts on integrated vs pre|power combo) Smurfin Integrated AV Amplifiers and Receivers 15 10-08-2003 10:02 AM
AV ForumsOptimised for Firefox.
