Hi i cant decide which home cinema system to buy.
the two are exactly the same price at pixmania:
http://www.pixmania.co.uk/uk/uk/1176...ys.html?type=i
http://www.pixmania.co.uk/uk/uk/5361...tml?itag=20958
there are pros and cons about both.
the sony has both coax and optical input. this is good because i need to connect the ps3 via optical.
The Philips only has coax input, but i have an optical to coax converter at home. the only problem is that im not sure if any sound quality would be lost.
The philips has the red and white connections at the back which the sony does not have. this is good because i can connect the tv to it.
the sony can upscale to 1080p but this does not matter to me because i have a 32" TV.
the philips has the tall boy rear speakers which is not very important for me but it is better.
i have heard a lot of good things about the sony, but this is not enough to convince me!
the other specs are about the same. can someone help im not sure which one to buy....
