Re: Change speaker cable
Copper oxidises pretty quickly and yes you should cut the end off your speaker cable once in a while.
I'm not sure how often it should be done but I guess I do it once every 3-4 months on average. But only on the back of my amp as all my speaker ends are fitted with banana plugs which stops/slows the process.
Living room: Sagem HD45, Pioneer VSX-D2011-S, Acoustic Energy AE120s, AE107c, Wharfedale Rears, Paradigm PS1000 Sub, Denon DVD1920, Sky+, Wii
Bedroom: Acer AL2671W, Pioneer VSX-909RDS, PS3, 4xMS302i's + MS304i, Yamaha YST-SW305, Sky+
