AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 28-06-2008, 10:20 AM   #1 (permalink)
Advice on NAD 5320 CD
I have an old NAD 5320 CD player which I haven't used in a while. When I last put it away everything worked fine except the drawer/tray wouldn't eject/close with the button - you had to press the button and then use a knife to help it open and then push it closed (after pressing the button).
Anyway, dug it out last week and the tray opened and closed fine for about 10 mins then the same problem.
Question I have is - is this a common problem and are these cd players worth getting fixed? It sounds fine when in use and it is in very good condition overall so I'm loath to just chuck it.
Any ideas/advice?
Rotel RA-02
Rotel RCD-02
Monitor Audio Silver 8i's
bam-bam is offline   Reply With Quote
Old 29-06-2008, 8:45 AM   #2 (permalink)
Thanks: Gave 3, Got 95
Re: Advice on NAD 5320 CD
I had a couple of NAD CD players years ago, including the same model as yours and a 501.
On reflection, I thought they sounded harsh, and the build quality was generally poor.
TBH, I wouldn't bother spending any money on it.
GW43 is offline   Reply With Quote
5320, advice, nad
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Advice: simple to use MP3 player advice? (also suggestion for speaker/DAB options) Dystran Portable Music (MP3, iPod etc.) 0 12-01-2008 9:31 AM
Revo DAB radio install advice - power advice needed (please) wydcus In Car Entertainment (ICE) 3 16-10-2006 8:43 AM
20''Philips 5320 or Sony KLVS19A10U viper330 LCD Televisions 2 12-11-2005 5:20 PM
Umax/Yamada DVD-5320/5520 DragonQ DVD Players (Standard Definition and Upscaling) 8 18-01-2005 10:04 PM
umax yamada 5320 goldfish14 DVD Players (Standard Definition and Upscaling) 0 08-03-2004 10:31 PM
AV ForumsOptimised for Firefox.
