AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 27-06-2008, 8:43 AM   #1 (permalink)
New turntable based system
First off i am posting for a friend not myself.
They want to buy a new system for the bedroom based around a turntable. It seems they are very interested in the Arcam Solo or mini solo, what turntable would you recommend to pair with this? And also, bearing in mind it is a bedroom and i am not sure of the size, suitable speakers. I don't think the Arcam has a phono input so which is the best phono pre-amp to get or are there any other alternatives to the Arcam?
Sharp 37GA4E | Denon 2805 | Mordant Short Genies | Xbox 360
Hyp3rion is offline   Reply With Quote
Old 27-06-2008, 10:01 AM   #2 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 158, Got 525
Re: New turntable based system
Originally Posted by Hyp3rion View Post
Hi...you really need to get an idea of price from your friend.
There are decent TT's available from not much over £200 incl cartridge,and phonostages from around £50 up,but some idea of what he wants to spend,and if he is willing to accept used gear to stretch the budget further,would be very useful.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline   Reply With Quote
Old 27-06-2008, 11:39 AM   #3 (permalink)
Thanks: Gave 28, Got 137
As Alex says dude you can easily have a TT system from £200. My personal favourites for VFM are Project TTs but you can buy second hand TTs like the Rega P2/P3 which are price comparible, add a nice little phono stage like the Cambridge Audio CA640p and you are off, so good in fact I am using one to great effect in my setup. FWIW Just seen another site where a chap is using a Project RPM5 with 33/45 speed change, £400 with a decent cart. Add the 640P and at £460 you have one of the nicest looking TT setups your likely to find for a while.
LP12 Val Akito DL110|Sony QS NS900V-QS MD920|Sony TAF-630ESD|Dynaudio Contour 1.3 II|Toshiba 36ZP48P|Toshiba SD9500|Sony RDR-HXD860S|BTVision|Primare A30.1 II|Diapason Emera|Van Dammed+Beldened+Neutriked|Power to stereo !!
CJROSS is offline   Reply With Quote
Old 27-06-2008, 11:51 AM   #4 (permalink)
Unfortunately they are being a bit vague on price but i imagine we should be looking at equipment that would compliment the Arcam Solo.
Would the Rega 3-24 wit Denon DL110 be overkill for this type of system, if its quality would not be realised then maybe a cheaper prject TT?
Old 27-06-2008, 11:53 AM   #5 (permalink)
Super Moderator
alexs2's Avatar
CJ as usual has given some excellent advice.....the Project,or a Rega would give good performance,and allied to a decent entry level phonostage such as the Cambridge,you have the beginnings of a good system that can be added to with time.
based, system, turntable
Refbacks are On
Thread Thread Starter Forum Replies Last Post
is there a HDD based system that... soweezy All-in-one Systems 3 20-01-2008 1:03 AM
non pc based system advice-needed Streamers and Network Music Players 14 15-12-2007 4:04 PM
FS Kef Q35.2 based system Ged Archive : Completed Business and Expired Threads 5 11-12-2006 10:13 PM
PC Based System? Joe90sDad DVD Recorders, Recording and Media 0 06-05-2006 5:38 PM
would a good pc based speaker system be better than say a bose system? Daddy k Speakers 6 09-01-2006 10:48 PM
AV ForumsOptimised for Firefox.
