AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 19-06-2007, 1:25 PM   #1 (permalink)
Thanks: Gave 10, Got 9
anyone give advice on this set-up?
HI
im looking to buy a new amp and speakers and stuff, im on a budget really though.
so far im pretty set on this:
-http://www.richersounds.com/showproduct.php?cda=showproduct&pid=YAMA-RXV359
cheap amp,but its got all i need, but i dont really know if its any good, ?
- ive also got a 2.1 bose acoustimass III series III. im pretty sure its an old system, but im thinking, for a man on a budget, these speakers should do me fine? i dont have much information on these, so if anyone wants to offer enlightenment, it would be much apreciated.
-http://www.richersounds.com/showproduct.php?cda=showproduct&pid=MISS-M3CLI-BLK
finally i was planning on buying that speaker for the center.
only problem i have now is i dont know where i can pick up 2 other regular small speakers for the two rear outputs... so it would be nice if someone pointed me in the right direction
anyway, like i said before, if you have any ideas on how i could make the set-up im planning on getting, it would be very apreciated
cheers
Pantera6 is offline   Reply With Quote
Old 19-06-2007, 1:38 PM   #2 (permalink)
Thanks: Gave 4, Got 944
Re: anyone give advice on this set-up?
Save yourself the hassle http://www.pixmania.co.uk/uk/uk/5420...ema-5-1-s.html get the complete package. Or sell the Bose system for what ever you can get and get a speaker system worth having like this http://www.petertyson.co.uk/ebuttonz...premiere.shtml bargin and great sound and it includes quality interconnects.
Andy98765 is online now   Reply With Quote
Pantera6 (19-06-2007)
Old 19-06-2007, 1:45 PM   #3 (permalink)
wow, that first yahama looks really good, and fits perfectly in my price range.
i acknowledge that this system probably isnt the most powerfull, but with 5x100W output, its surely better than my current system.
flogging the bose speakers should bring me around £60 i think, so thats not bad.
Old 19-06-2007, 8:52 PM   #4 (permalink)
la gran siete's Avatar
Location: Deep in the bowels of sussex where the angloargies live
Thanks: Gave 809, Got 410
I am assuming you like th sound of the Bose ? So why not buy the best AV amp you can afford - Yamaha , Denon or Cambridge(the latter are good with music) and then when funds allow replace the speakers. Have you thought of contacting a Bose dealer to see if extra rear satelites and a matching ctr speaker can be bought to go with what you have?BTW its important to match ctr with front lft and rgt.
LGS Dedicated member of the Anglo Argentine RAJ
la gran siete is online now   Reply With Quote
Old 19-06-2007, 10:00 PM   #5 (permalink)
aaaa, didnt know that.
how come though? sorry, i really have no idea why..
i doubt i can afford bose speakers these days though
Old 20-06-2007, 5:47 AM   #6 (permalink)
its a question og getting the tone right, The rears are not so important as they are for sounbd effects but the ctr is the main hombre for you get all the dialogue from there and it needs to to work well with the two fronts.maybe if you just bought a matching ctr for now and got some cheapy rears later from Ebay.Tbh I dont know Bose that well but would have thought it was worth contacting a dealer.
do they look like these?
http://cgi.ebay.co.uk/Bose-Acoustima...QQcmdZViewItem
Old 20-06-2007, 4:06 PM   #7 (permalink)
the speakers are exactly the same, but the subwoofer slightly different
Old 20-06-2007, 4:59 PM   #8 (permalink)
lazymatt's Avatar
Thanks: Gave 7, Got 213
Watch it with the Acoustimass module. I'm not up on Bose, but the satellites are pretty delicate, and easily blown. I believe they are controlled through the Acoustimass module, and sometimes they cannot be used with normal amps.
Have a search round on the forums, there's plenty of people who have asked similar questions, and I'm sure you'll find some useful info.
Matt
lazymatt is offline   Reply With Quote
advice, give, setup
Refbacks are On
AV ForumsOptimised for Firefox.
