AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 13-06-2007, 9:26 PM   #1 (permalink)
lintwind
Posts: n/a
Pioneer PL-340 turntable
Hi all, i need a bit of advice, whether anyone had any experience of Pioneer PL-340 turntable or any other Pioneer TTs for that matter, their own/factory-fitted cartridges/styli and their overall sound quality and performance. Many thanks in advance.
Old 14-06-2007, 1:35 PM   #2 (permalink)
Beobloke's Avatar
Thanks: Gave 3, Got 46
Re: Pioneer PL-340 turntable
The PL-340 was a fairly basic Pioneer deck, with a plastic plinth and pretty light platter. If it has a standard Pioneer cartridge, this is highly likely to be a budget Audio Technica of some sort.
Should sound respectable enough, but nothing to get really excited about.
Don't believe anyone who tells you nothing rhymes with orange. It doesn't.
Beobloke is offline   Reply With Quote
lintwind (14-06-2007)
pioneer, pl340, turntable
Refbacks are On
AV ForumsOptimised for Firefox.
