AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 20-07-2002, 7:40 PM   #1 (permalink)
Thanks: Gave 62, Got 17
Amp with component output ?
Im after a good quality attractive A/V amp with lots of inputs and component output. It should preferably be a seperate of a good hi-fi and speakers with Multi-region DVD player..
I'm looking to spend under £1000 on the whole lot ...
Suggestions and links will be appreciated.
kamaran is offline   Reply With Quote
Old 20-07-2002, 8:25 PM   #2 (permalink)
chris thomas
Posts: n/a
Denon 3802, a great amp for about £650 now, was about £900 when it came out, put a search in on this forum for it, there,s loads of threads on it .
Old 20-07-2002, 8:40 PM   #3 (permalink)
Thanks Chris, seems this is the one most people are recomending is it really worth the extra cash over the Denon 2802 ?
Can you get matching Tuner / DVD unit for these ?
Old 20-07-2002, 9:09 PM   #4 (permalink)
chris thomas
Posts: n/a
Kamaran. i,d definetly go for the 3802 but the 2802 is still decent, main differences are the 2802 has 24bit processor compared to the 3802,s 32 bit,
power is 90 watts compare to 105,
but a main differance is the 3802 is 7 channell and is said to be quite allot better for music than the 2802.
It has a tuner built in, has for matching dvd, denon do quite a few but i,ve never really looked.
amp, component, output
Refbacks are On
AV ForumsOptimised for Firefox.
