AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 04-10-2006, 9:20 PM   #1 (permalink)
Thanks: Gave 2, Got 3
Decent preamps?
I have been upgrading here and there, and now feel that the only thing missing is a good quality 2nd hand preamp. I know very little about which preamps stand out from the crowd - my budget would be a measly £200-£300.
I do know that it has to have a good headphone-out.
If it makes any difference, it would be plugged into a nad c272 power amp running Quad 21L speakers - input would be from an old cambridge audio dacmagic 2i.
Any direction would be cool... so far the only thing I have seen that seems to fit is the Audiolab 8000q. Am I right in thinking that there aren't any good NAD budget preamps?
Dusteh is offline   Reply With Quote
Old 09-10-2006, 12:44 PM   #2 (permalink)
Thanks: Gave 0, Got 2
Re: Decent preamps?
I have been considering the Audiolab 8000Q to run as a pre-amp into the HT input of my Musical Fidelity A3.5 - the variable gain of the 8000Q appeals since I do quite a bit of late night, low level listening and find that the bottom end of the A3.5 volume control to be quite coarse and uneven.
ultrawomble is offline   Reply With Quote
Old 09-10-2006, 9:37 PM   #3 (permalink)
Helicon's Avatar
Thanks: Gave 49, Got 205
Re: Decent preamps?
There are a lot of mediocre pre-amps out there, and very few world class ones. For the budget you have, definitely look at the second hand market. The Audiolabs are a good start.
AV Mitsubishi HC6000 / Yamaha RXV3800 / Sony BDPS350 / Pioneer DV737 / Toshiba EP35 / M&K LCR651 / M&K S55 / M&K VX850SF / 360 Elite / Wii / retro consoles
Hi-Fi Cyrus CDXTse / DACXP / Mono X x6 / PSXR x2 / KEF Reference 205.2
Helicon is offline   Reply With Quote
Old 10-10-2006, 12:48 AM   #4 (permalink)
nsherin's Avatar
Thanks: Gave 19, Got 22
Re: Decent preamps?
Any of the NAD integrateds - such as the C352 or C320BEE can be used as a preamp. Simply run the pre-outs to your power amp. Either of those amps are excellent value for money - I use the C320BEE as an integrated (pre/power in one box) and it does a stunning job at that! I'd be wary of mixing brands between pre/power, as each brand has its own 'house sound'. By going with one brand, you'll likely get a more balanced sound.
Sources: Sony RCD-W100 / MDS-JB980 / RDR-HXD560, Denon TU-1800, Pro-Ject Debut II, iPod Classic 160GB/Onkyo DS-A2X Dock Amps: Onkyo TX-SR606, Rega Fono Mini Speakers: Canton Movie 80 CX
nsherin is offline   Reply With Quote
Old 10-10-2006, 6:58 AM   #5 (permalink)
Helicon's Avatar
Re: Decent preamps?
But a good quality dedicated pre will do a far better job than an integrated amp will.
decent, preamps
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wanted, a place that sells decent LCDs at decent prices but has no interest free etc! NackNack LCD Televisions 5 18-09-2006 12:55 PM
Stereo preamps with video switching - do they exist ? Glenn Coombs Audio Processors and Power Amps 5 01-02-2006 1:29 PM
Rotel vs Bryston preamps contoursvt Hi Fi Systems and Separates 2 16-01-2006 5:04 AM
Can a poweramp accept 2 seperate preamps? rajkat Audio Processors and Power Amps 8 01-11-2005 5:59 PM
Decent MP3 Player at a Decent price?? barneybeerbelly AV Hardware Bargains and Discount Codes 0 16-11-2002 3:04 PM
AV ForumsOptimised for Firefox.
