30-05-2006, 6:26 PM
#1 (permalink)
Thanks: Gave 4, Got 32
Where to buy isopropyl?
Right, as the title suggests.
I want some Isopropyl alcohol to clean my LPs and am having some trouble locating it. No local chemists seem to have it but for one, who wants to relieve me of £6 for a 600ml bottle! Boots have nothing, Superdrug have nothing...
So where do you guys get yours?
C272, DAC-1, Debut III, 540P, CM1, XLS300/PR, Silver Ann. XT
30-05-2006, 6:29 PM
#2 (permalink)
Thanks: Gave 165, Got 386
RS components, CPC or Maplins should all be able to help.
30-05-2006, 6:47 PM
#3 (permalink)
Thanks: Gave 578, Got 341
hate to jump on your thread, but how do you apply it and take it off?
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Roku Sound bridge M1000,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, XBox 360, PS3,Harmony 885
30-05-2006, 6:50 PM
#4 (permalink)
RS Components and Maplins only seem to sell the stuff in the spray-cans, is this just as good? Would one put this straight onto a cloth that is dampened with distilled water and then run over the LP?
Much appreciated
30-05-2006, 7:03 PM
#5 (permalink)
Any Chemists should be able to make a solution of 90% it is alcahol, that's all, just the Chemical name for it.
I wouldn't clean Vinyl with it at all ! use ordinary soapy water and a Micro Fibre cloth, the very soft ones.
It is normally used for cleaning off thermal paste off CPU's !
30-05-2006, 9:40 PM
#6 (permalink)
Thanks: Gave 78, Got 385
That's not such a bad price.
31-05-2006, 6:22 AM
#7 (permalink)
Thanks: Gave 32, Got 166
The big chemist chains no longer stock isopropyl alcohol, but they can get it to order. I was told that the reason it isn't stocked is health & safety legislation - flammable products require approved secure storage.
I wouldn't have thought it was a good idea to use alcohol to clean LPs too often. It'll strip the lubricant from the surface, and may actually damage the vinyl.
The stuff in spray/pump cans (used as floppy drive or tape head cleaner) is the same.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
31-05-2006, 6:49 AM
#8 (permalink)
Super Moderator
Thanks: Gave 175, Got 692
....and before anybody leaps to a conclusion, Isopropyl Alcohol (Iso-Propanol) is NOT the same substance that's found in alcoholic drinks (known for its intoxicating effects on certain carbon-based lifeforms); that's Ethanol. Curiously, IsoPropyl Alcohol is available on the shelf for self-service in drugstores, WalMart, etc., in the USA. It's some time since I last bought any in the UK, but when I did, Boots obtained it for me.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
31-05-2006, 8:21 AM
#10 (permalink)
Thanks: Gave 114, Got 138
Find a local printers in the Yellow Pages. Most printers use litres of it and I'm sure they would let you have a small amount FOC.
www.flickr.com/photos/simonr_uk It's a work in progress!
31-05-2006, 8:33 AM
#11 (permalink)
Thanks: Gave 1, Got 3
If you do get hold of some, you must dilute it with water, purified water is best but boiled (and cooled), filtered water will suffice, about 50/50 at least, some may say 75/25 in favour of water.
I am lucky enough to get some from work and I use it with great effect on dirty vinyl, just dont get it on the label in the centre - and dont go anywhere near a flame!
31-05-2006, 8:39 AM
#12 (permalink)
I put a mixture of IPA/water in an unused and thoroughly clean garden spray bottle, apply a generous amount to lint free cloth, lint free is very important, and wipe on to the vinyl in the direction of the grooves, allow to dry on a clean and dry surface (not long as the IPA will accelerate the process), then play!
I use latex gloves when doing mine as you can handle the vinyl freely and not worry about the mixture getting over your hands - not that its terribly hazardous to skin but it may cause a reaction if your sensitive.
31-05-2006, 8:51 AM
#13 (permalink)
Thanks: Gave 270, Got 184
I know isopropyl leave a residue, which would not be good for vinyl grooves. To what extent this happens when diluted I don't know. I cut records, & we don't clean the cutting stylus with isopropyl because of the residue; we use acetone, which is getting pretty difficult to buy, due to tighter restrictions on these materials; we have to fill out forms etc. to get any quantity.
My HT. It's Here
I love the smell of AV in the morning
31-05-2006, 9:23 AM
#14 (permalink)
Super Moderator
I use a mix of approx 50/50 Isopropyl and Distilled Water and add a tiny drop of detergent (which makes it spread better). And I play my records while still wet with this mix. This, I find, gives the "cleanest" sounding result. It does no harm (that I can detect) to the record UNLESS there is any acetate in the compound. 78's and certain early US pressings do have acetate and this IS damaged by the alcohol. And it hasn't harmed (that I can detect) either of the two styli I use.
However, if you leave it to dry on the record, it leaves a very noisy residue which, I suspect, is gunk (release compounds or similar) that was on the record in the first place, not from the solution. So either:
it must be thoroughly dried off with a cloth before it dries by itself
or:
the record must be wet with the same mix again before playing a second/subsequent time.
Nigel
31-05-2006, 11:07 PM
#15 (permalink)
