AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 29-05-2006, 1:11 PM   #1 (permalink)
doctorjuggles's Avatar
Thanks: Gave 14, Got 11
Amplifier switching?
Need a bit of help/advice on something.
For some reason, you can buy countless switches that enable you to switch from one amp to several pairs of speakers, but I can't find a single product that allows me to use the same speakers but for two amps (one stereo, one AV)
Is there a way around this problem, or will I just have to have two sets of speaker cables and switch them over manually every time I want to switch between AV and stereo?
By the way, I know you can use an AV amp's pre-outs and have the stereo amp driving the fronts and the AV handling surround, but I don't want to do that.
Any advice?
doctorjuggles is online now
Old 29-05-2006, 2:29 PM   #2 (permalink)
Thanks: Gave 3, Got 13
here you go.
http://www.maplin.co.uk/Module.aspx?...witch&doy=29m5
Audiolab 8000Q, 2XAudiolab 8000M, Exposure CD2010, Spendor s6e, Atlas All Cu cables.
mr_seanstanley is offline
doctorjuggles (29-05-2006)
Old 30-05-2006, 9:41 AM   #3 (permalink)
Thanks mr_seanstanley.
Tried checking around under those search parameters and Maplin seems to be the only place that sells anything of that sort, which surprised me considering the general opinion that AV and stereo setups should be kept separate. I'd have thought a few higher quality options would have been available.
Anyway, I've ordered one, so we'll see how it goes.
Thanks again
Old 30-05-2006, 10:28 AM   #4 (permalink)
You're more than welcome. I was using one of those for about 2 years. the switches started to go towards the end but this isnt bad considering that the switch was used 2-3 times a day.
Ive never seen another design like it which is a bit odd. a niche in the market there for one of the cable companies to come along and make a high quality one i think!
lets hope they watch the forums....
Old 12-06-2006, 1:29 PM   #5 (permalink)
Thanks: Gave 127, Got 57
Do you mind if I ask why you don't want to use the pre-amp from the AV for stereo? I am looking at switching an old AV-amp to something better, but some suggest that separate amps with this pathway might be better. It sound tricky to me and I am no expert, which is why I would be interested in your thoughts! Thanks
proux is offline
Old 12-06-2006, 1:39 PM   #6 (permalink)
Two reasons.
Firstly, I don't like the stereo sound out of the AV receiver, and therefore don't trust anything going through it for stereo purposes. I know the signal is supposed to be untouched, but if the signal doesn't need to travel that far then I'd rather avoid it.
Secondly, I don't really see the point of having both the amp and the AV receiver on permanently all the time every time I want to watch TV or listen to music. While the cost of the electricity might not be that much extra, what's the point in having every piece of electronics in the house on just to watch the news? It just seems like overkill to me.
But the main thing was the first point. I want two separate systems, one for AV, one for stereo. I don't want either of them pretending they can do the other's job. When I'm listening to music, I'll have the stereo setup working and when I'm watching TV or a movie, it's the AV receiver.
Old 12-06-2006, 2:01 PM   #7 (permalink)
Thanks, sounds sensible, I am not sure what to go for myself. At any rate, I have such a basic DVD/CD player, that adding a proper CD player through the AV might just be enough to make me happy!
proux is offline
Old 21-06-2006, 10:48 PM   #8 (permalink)
thedude's Avatar
Thanks: Gave 1, Got 2
i use the preouts on my Av Amp to my stereo amp sounds good on stereo with the "straight" button activated. However the only reason and real reason should be for listening to CDs or Radio and i use just my stereo amp for that and turn the AV amp off when i want to do that.
Thats my personal opinion and works well for me
Hitachi PD7200, Yamaha RXV2400 5.1 amp, SKY HD+, Myryad MXI2150 int amp, Arcam CD62, AELITE 3 fronts, AE EVO centre, Celestion F1 Rears, Rel Q100E sub and Playstation 3.
thedude is offline
Old 30-06-2006, 12:48 AM   #9 (permalink)
Balance ?
Is it easy to balance the AV sound levels of each speaker. When set up, does adjusting the master volume on the AV amp adjust the out levels to the Stereo amp?
Does auto set up feature on the AV amp still work, even sending the signal for the fronts through the Stereo amp ?
FrancisG is offline
amplifier, switching
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
