AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 28-05-2006, 7:47 PM   #1 (permalink)
Thanks: Gave 1, Got 2
Buzzing from stereo amplifier, is it faulty?
Disclaimer: I'm a complete AV noob, so may not know what I'm talking about
I recently purchased a second hand stereo amp (Denon PMA-355) for light use. With nothing but a set of speakers connected the amp generates a kind of buzz, which modulates about 4 times as the volume is increased. This can also be heard quite prominently via the headphone socket and is very annoying. Is it simply a faulty component that could be repaired by someone qualified?
Any help appreciated.
sadbuttrue is offline
Old 30-05-2006, 9:00 AM   #2 (permalink)
Thanks: Gave 3, Got 13
Is the buzz coming from inside the amplifier chassis or from the speakers?
Audiolab 8000Q, 2XAudiolab 8000M, Exposure CD2010, Spendor s6e, Atlas All Cu cables.
mr_seanstanley is offline
Old 30-05-2006, 12:29 PM   #3 (permalink)
The buzz comes from both speakers and headphones.
Old 30-05-2006, 12:41 PM   #4 (permalink)
have you got any source components connected when it makes the buzzing?
Old 30-05-2006, 5:51 PM   #5 (permalink)
michael orme's Avatar
Thanks: Gave 3, Got 2
Buzzing.
Check if it needs to be earthed, and if it is, I bought an amp once, the earth lead was detached in the plug. Its worth trying before you start spending money.
michael orme is offline
Old 31-05-2006, 6:26 AM   #6 (permalink)
clockworks's Avatar
Thanks: Gave 32, Got 166
Have you tried it with a source component connected? You may find that the buzzing stops when you connect a CD player - the amp may be picking up interference with the inputs "floating".
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
clockworks is offline
Old 31-05-2006, 11:17 AM   #7 (permalink)
I've tried with and without a source connected, the result is the same. I thought it could be some local interference, so have tried it in another part of the house. It has the factory fitted moulded plug, so if it needs earthing it should already be.
Old 31-05-2006, 5:34 PM   #8 (permalink)
clockworks's Avatar
I've had some wierd problems with buzzing/warbling noises. To get to the bottom of it, I went right round the house, unplugging or turning everything off. I also tripped all the circuit breakers, except for the one supplying the AV system.
The main problem was the LCD TV in the kitchen. On standby, it was generating interference, which was then fed throughout the house via the coax cabling. Turning it off at the main switched fixed that.
Another problem was with a power amp. I had to disconnect the cable inside the amp that connected the chassis to the earth pin on the IEC mains inlet socket. The chassis is still earthed via the phono leads to the rest of the system. Having two earth paths was causing the problem.
If you go through all these checks, and it still happens, it's probably a faulty amp. If it comes through both channels, it's probably a fault in the power supply, maybe a capacitor breaking down. Should be a simple fix for an old-fashioned TV/hifi repairman. Take it direct to the repairer, not to a shop - they'll probably double the price.
Old 01-06-2006, 1:07 PM   #9 (permalink)
Thanks clockworks, I'll give your idea a try later today. Hopefully it's not something I actually need switched on or in standby causing the problem.
amplifier, buzzing, faulty, stereo
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
