AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 28-05-2006, 2:59 PM   #1 (permalink)
220v Amp/DAC on 240v UK supply...bad ?
Hi there,
I'm getting the above which work off 220v not 240. Is it dangerous to run these from 240v or should I look to method of getting 220v.
Whats therefore the simplest way to convert 240v down to 220v.....
many thanks
Neil
hendern88 is offline
Old 28-05-2006, 4:30 PM   #2 (permalink)
ghislain's Avatar
Thanks: Gave 7, Got 37
Hi Neil,
Would not worry too much - our 220V is not always 220V anyway
Since all of the inside electronics are running on either 5V or 12V, its the transformer that'll take care of that.
If you're really not comfortable, replace the 220V transformer inside the unit with a 240V one.
ghislain is offline
Old 28-05-2006, 6:52 PM   #3 (permalink)
Would it be wise to run these via some 240v to 220v adapter sockets....or is there no need to fear blowing/buring out the transformer.
thanks again
Neil
Old 28-05-2006, 7:36 PM   #4 (permalink)
ghislain's Avatar
Neil,
I am afraid I am not familiar with the sockets you are talking about so I can't confirm or deny that.
If I remember correctly most transormers are rated 220-240V on their primaries anyway so I would not be worried.
Present tolerance is +/- 10% and most devices can easily cope with that.
Within the european union there's an agreement to gradually and transparantly standardize on 230V anyway (compromise between the UK and the main land ). This will have no significant influence for our 'every day devices' - ok, there'll be a slightly larger current flow which can slightly increase the amount of generated heat which in turn potentially influences the life span of the device but again, I would not dramatize this at all.
ghislain is offline
Old 28-05-2006, 8:18 PM   #5 (permalink)
thanks mate,
Old 28-05-2006, 9:20 PM   #6 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 146, Got 501
The only real problems,given the variation in mains voltage at certain times of the day,has been with some Chinese imports,using 220V transformers,as part of valve PSU's,where the stepped up voltages to run the tubes has resulted in the rectifiers being run at or above their design tolerances.
I am not aware of anyone here or elsewhere reporting it as a problem with solid state gear.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline
220v, 240v, amp or dac, supplybad
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
