AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 26-05-2006, 11:19 PM   #1 (permalink)
Upgrade help needed!
Can you please help me? I'm looking to upgrade my current system and am really stuck as to which piece to upgrade and how much money I need to spend that will make a real difference. My current system consists of Rega Planner 3, RB300 arm, Roksan Chorus black Cartridge, Arcam Alpha 7se CD player, Cyrus 1 amp, and Acoustic Energy Aegis Evo 3 speakers. I have developed this system over many years and have to admit it sounds absolutely fantastic, but I now want to take it to another level but I don't really know which bit to change that will give me the biggest improvement. Any advice will be gratefully appreciated.
Many thanks
yello is offline
Old 27-05-2006, 10:53 AM   #2 (permalink)
karkus30's Avatar
Thanks: Gave 42, Got 103
Thats a difficult one TBH. Your vinyl replay system is pretty decent and so is the CD player. The Cyrus Amp is getting a bit long in the tooth but is still a nice little amplifier. You seem to like the sound of the system so I guess your also happy with the speakers which I would have put down as a bit of a weak link.
Small steps are needed to see an improvement, see if you can get hold of a couple of amps to slot into the system and see if you like what they do. I would try an LFD silver intergrated, a Soneteer, something from Naim (I always recommend a 72/140 pre power), something more modern from Cyrus etc. Just different styles and sounds.
It all depends what your looking to improve on.
karkus30 is offline
needed, upgrade
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
