AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 26-05-2006, 3:48 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Replacement Turntable - Project Debut 3?
My old Dual CS 505-4 has died on me, it lifts off of records before they end. I can't see anything on it to adjust and cannot find anyone local who is willing to repair it. So I need to find a replacement for it. It sounded fine to me plugged into my Yamaha AX-592 amp, and as I don't listen to vinyl too often I don't want to spend a lot of money on a replacement.
I have seen a Project Debut 3 on Richer Sounds site for less than £130. Would this be as good as my old Dual? Also will it come with a cartridge or do I need to budget extra for this?
Thanks in advance for your help.
colin.bee is offline
Old 26-05-2006, 10:14 PM   #2 (permalink)
Thanks: Gave 4, Got 32
I have not heard your previous turntable and therefore cannot offer you any form of comparison, but countless members on here (including myself) have plenty of praise for the Pro-Ject.
There is nothing fancy or convenient about it, it does not lift off of records at the end, it doesn't have a nice button to change the speed, all very much manually operated...
A bit of set up is also required and I warn the manual is not what one would call jargon-free. Worth the patience, however.
The Ortofon OM5E cartridge is supplied, along with a Pro-Ject tone-arm. All that is required is a suitable MM phono stage to sit between the turntable and your amp (unless your amp has one built in) and you are off!
C272, DAC-1, Debut III, 540P, CM1, XLS300/PR, Silver Ann. XT
Spangle2k5 is offline
colin.bee (28-05-2006)
Old 26-05-2006, 11:26 PM   #3 (permalink)
nsherin's Avatar
Thanks: Gave 19, Got 21
A cracking deck for the money - I use the older Debut II through a Rotel RQ-970 MM/MC phono stage and the result is a stunning vinyl setup for the money (IMHO).
Sources: Sony RCD-W100 / MDS-JB980 / RDR-HXD560, Denon TU-1800, Pro-Ject Debut II, iPod Classic 160GB/Onkyo DS-A2X Dock Amps: Onkyo TX-SR606, Rega Fono Mini Speakers: Mission m70
nsherin is offline
Old 28-05-2006, 2:37 PM   #4 (permalink)
Thanks for your help and advice!
Colin.
debut, project, replacement, turntable
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
