24-05-2006, 11:46 PM
#1 (permalink)
Thanks: Gave 14, Got 7
£1000 to spend on a steroe setup.
Been asked by a friend to recommend a CD player, amp, pair of speakers, speaker stands and cables for £1000. I've currently got a Denon 3805 and Arcam DV88+, he just wants a music only system though so i could do with some help.
The only definate i could recommend were either Quad 11L (£300) or Quad L-ite (£150) speakers.
25-05-2006, 6:26 AM
#2 (permalink)
Thanks: Gave 32, Got 166
How about buying secondhand?
£600 or so should be enough to buy a secondhand CD player and integrated amp from a respected British manufacturer (entry-level Linn, Naim, etc., or something from Arcam, Cyrus or Quad).
Speaker choice is a bit more difficult (personal taste). The L-ites would work well in a small room, but need help from a sub in a big room if you like lots of bass.
Might be best to get the amp and CD player, then take those to a shop and listen to some speakers.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
25-05-2006, 8:33 AM
#3 (permalink)
Thanks: Gave 3, Got 95
Second-hand/ex-demo is fine for amps and speakers, but CD players have a bit more to go wrong, and care should be taken. However, in all cases, old models being sold off cheaply would also be a good bet. There's likley to be very little difference between old and new models of amps and speakers, and CD players for that matter.
Get them from a dealer, and you'll probqbly get a few months warranty as well - and either save a lot of money, or get a better system for your £1,000.
25-05-2006, 10:23 AM
#4 (permalink)
Thanks: Gave 13, Got 214
I would suggest a hard look at the Rotel RA 06 series as discussed here.
This should be a decent sounding combination and should take some of the guess work out of your choices. The RA06 and perhaps the RA05 amp should leave enough for decent speakers. Finish off with interconnects from the special buys here and Van Damme proffesional speaker cable from Maplins and you should be able to scrape in on budget.
Denon DVD-3910, Denon DVR-3805, Hitachi 32pd5200, 3x Castle Compact LCR's 2x Castle surrounds, Compact Sub
Denon DVD2900, Benchmark DAC1, Cambridge Audio 840A, ProAc Response 1SC
My personal opinions are not those of the AV Forums or any other related website.
25-05-2006, 11:00 AM
#5 (permalink)
I have just recently put together a system for myself for around £900 that sounds realy good
marantz cd 5001ose, marantz pm7200 and b&w dm603 s3
granted i have done some mods to the cd player but it sounds superb and looks the mutts as well
25-05-2006, 12:56 PM
#6 (permalink)
Thanks, i'll have a look around.
