Originally Posted by Legzr1
Bob,
I too have the 308 pre/power combo but your question is a bit confusing...
You say the pre/power is for music only so where does LFE come into it?
Of course you're right
I used the term LFE but really I should have said bass re-direction
I have two PB12 subs which I like to handle the lower frequencies below about 80 hz. My main speakers are generally excellent but the lower frequencies cause small vibrations in a couple of the drivers and I have used the bass management of the 3806 to smooth them out. I guess it would be better to get the drivers looked at but still I'd like similar control of my music to that which I have with movies (so I can mess that up as well
Knyght Byte, I could use the 3806 in various ways but would really like to keep it out of the chain if I could. I really bought the MF gear because I wanted to go a bit purer with my music so maybe I should just use loop out, send the full signal to the subs and stop messing about
