AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 21-05-2006, 12:58 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Recommend me a soundcard for stereo setup
Hi all,
Have got the following, Monitor Audio rs6's, Marantz pm7200 amp, conected to a self built PC using a Creative Audigy2zs soundcard, now I know a pc isn't the best way for music ( a cdp is best ) but I have no choice but to stay with the pc, so I need the best soundcard for stereo playback only.
Budget is £100ish and I need the option of hooking up a dac via digital at a later date.
Many thanks.
Babyface UK
Babyfaceuk is offline
Old 21-05-2006, 6:52 PM   #2 (permalink)
Knyght_byte's Avatar
Thanks: Gave 83, Got 490
you could move up to the X-Fi series by Creative, or M-Audio, they often have good soundcards for music....
otherwise you need to be looking at more professional type cards, which can be had cheap sometimes if lucky, but not all that often, if you dont mind going secondhand you can pick up some lovely Yamahas if you hang around for them....heh
HC: Infocus 7205, Denon 3803/3910. MA Silver S6, SFX, S2, SLCR. SVS PB12/Plus. Sky+.
Hifi: Musical Fidelity A5, Denon 3910 CD/SACD/DVD-A. Monitor Audio GR10's.
PC: E6700, Gigabyte DS3 965P, 2Gb Corsair, Gainward 8800GTS 640Mb, CL X-Fi Fatal1ty, Jeantech 600w, Antec Sonata II.
Knyght_byte is offline
Babyfaceuk (21-05-2006)
Old 21-05-2006, 8:01 PM   #3 (permalink)
been looking at the M-Audio 192 http://www.maudio.co.uk/products/en_...e192-main.html
it has 1/4" trs outputs, how do I connect this to the rca jacks on my amp,
Babyface UK
Old 21-05-2006, 8:18 PM   #4 (permalink)
Thanks: Gave 1, Got 6
This site probably has the job for that:
http://www.studiospares.com/
Rotel RA-01, B&W DM602, NAD C521BEE
Dr.EM is offline
Old 21-05-2006, 9:12 PM   #5 (permalink)
Thanks: Gave 3, Got 13
these caught my attention a while ago.
http://www.russandrews.com/lookup/1/...dcard-4700.htm
Audiolab 8000Q, 2XAudiolab 8000M, Exposure CD2010, Spendor s6e, Atlas All Cu cables.
mr_seanstanley is offline
Old 23-05-2006, 1:12 PM   #6 (permalink)
Follow up,
Got a M-audio 192 soundcard to replace the Audigy 2zs and the difference is astounding. Sound stage is much wider and the 192 shows detail not heard in the ol 2zs.
Recommended to anyone thinking of doing the same.
Babyface UK
Old 24-05-2006, 12:49 PM   #7 (permalink)
Also anyone looking into a decent stereo sound card should take a look at the E-mu 0404. I belive its the professional brand of creative. I got one of these cards for mp3 duty and its fantastic for only £70.
Teifiterror is offline
recommend, setup, soundcard, stereo
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
