21-05-2006, 8:49 AM
#1 (permalink)
Thanks: Gave 1, Got 2
Switching from DVD player to CD player to listen to CDs
Hi guys!
It's been bugging me for a while, and the time has now come to finally purchase a dedicated CD player for my system. All these years I had DVD players to run my CDs, but that's over. Alas, I have avery limited budget (150 quid absolute max), and I'm not looking into buying the ultimate disc spinner either, given that I will use my current system (see signature) to play discs. SACD is not really of any interest (the DV565 plays them), only CD really. I have been looking for a week at various prices available, but would like to know if anyone has a descent experience with a player in my price range? I appreciate all your help
Too much stuff to list here, link coming soon
PS3 ID: monochronomicon
Xbox Live GT: monochronomicon
21-05-2006, 9:58 AM
#2 (permalink)
Thanks: Gave 13, Got 214
The NAD C521 BEE is £150 at Richer Sounds. It has plenty of enthusiastic fans and I would consider it on a shortlist to listen to. Compare to the Cambridge Audio 540C. Same price at the moment but again has its followers.
Denon DVD-3910, Denon DVR-3805, Hitachi 32pd5200, 3x Castle Compact LCR's 2x Castle surrounds, Compact Sub
Denon DVD2900, Benchmark DAC1, Cambridge Audio 840A, ProAc Response 1SC
My personal opinions are not those of the AV Forums or any other related website.
21-05-2006, 12:22 PM
#3 (permalink)
Thanks for your advice - I will look into these two. Even with the setup I'm currently using, do you think this will make a difference?
21-05-2006, 1:58 PM
#4 (permalink)
I think it will personally but you still have to listen to make the final choice.
21-05-2006, 2:33 PM
#5 (permalink)
Thanks: Gave 1, Got 6
Rotel RA-01, B&W DM602, NAD C521BEE
21-05-2006, 3:18 PM
#6 (permalink)
Actually I meant the difference between the CD player and the DVD player - not the difference between the players you suggested. Even then it might just be down to my ears
21-05-2006, 9:22 PM
#7 (permalink)
I was talking about the dvd/cd comparison too. The choice isn't just which cd but if you consider even needing to upgrade is required. I did, many don't.
