Originally Posted by scroggie
I own a Rothwell power amp that uses ECC83 (12AX7) and EL84 valves. The existing valves have been in use for several years and I want to put in some replacement tubes. I would like to obtain a warm sound without a bright sounding treble. Having read some stuff on the web I still can't find any informative reviews in order to decide what make of valves would be the best to opt for. Any views would be appreciated.
Steve
well, the obvious answer would be get some NOS valves, but it could be pretty expensive ( Mullard, Philips Miniwatt, Telefunken...). other than that, the choice could be some Sovtek, JJ, EI.
well, of the new ECC83 the good choice could be Sovtek 12AX7LPS or EI Elite Gold.
about EL84, EI Elite again, or Sovtek EL84.
they could be found pretty easily, but if you have money and time try to locate some Philips Miniwatt or Siemens 12AX7, maybe Tungsram ECC83.
