26-03-2006, 11:27 AM
#1 (permalink)
Bush Record Deck
Hi all
Anyone got any views on the bush record deck that Richer Sounds sell for £39.99. I plan to use it as a way of transferring all my old LP's to my computer. This deck has a Pre amp built in so I am hoping it will save me the bother of using a seperate amp. I am not that bothered about quality and being a bit of a snob i wouldn't normally consider having Bush equipment in my house, nut I think it might just do the job I require.
If I am talking out of my hat please letr me know before I waste my 40 Quid
Ta
Matt
26-03-2006, 11:48 AM
#2 (permalink)
Thanks: Gave 2, Got 7
If you're not bothered about quality I'm sure it will be fine. What have you got to lose? if it doesn't work, just take it back!
(If you are bothered by quality I wouldn't touch it with a barge pole!)
Bill
27-03-2006, 12:47 PM
#3 (permalink)
Thanks: Gave 1, Got 4
If you mean the Bush MTT1, then I've been using if for transferring from vinyl to CD (via yamaha HD1300). It seems to do the job pretty well, with no noticeable turntable noise, and a nice crisp sound, once the LPs have been given a quick scrub. I bought mine when it was £100, so £40 seems like a good deal...
KJP
27-03-2006, 5:17 PM
#4 (permalink)
Yes it is the MTT1 and it is actually £49.95.
I assume I will need some software to carry out the transfer. What are you using and is it easy to use?
27-03-2006, 5:19 PM
#5 (permalink)
Just realised that you are doing it straight to CD, so probably dont need software.
Anyone got any suggestions gratefully recieved
27-03-2006, 8:28 PM
#6 (permalink)
Thanks: Gave 14, Got 6
got this tt too - it's fine, sounds surprisingly good for the money. Very light, and not much isolation, so if you're going to be doing anything that might 'jolt' it through the floor than some extra isolation (e.g. put it on a shelf...or put some cheap rubber supports underneath it). For £40, though, has to be a good deal
28-03-2006, 7:23 AM
#7 (permalink)
Thanks: Gave 26, Got 128
Must concur with the chaps here, I used to own a TT1 too years ago, excellent little device. But I would say if you spend £100 and get a Project Debut, you are in the first realms of Hifi TTs IMHO.
LP12 Val Akito DL110|CA640p|Sony QS NS900V-QS MD920|Sony TAF-630ESD|Dynaudio Contour 1.3 II|Toshiba 36ZP48P|Toshiba SD9500|Sony RDR-HXD860S|BTVision|Primare A30.1 II|Diapason Emera|Van Dammed+Beldened+Neutriked|Power to stereo !!
28-03-2006, 5:08 PM
#8 (permalink)
Bit the bullet and bought one today, just need to find out what software if any that i need. Any suggestions??
28-03-2006, 9:06 PM
#9 (permalink)
Thanks: Gave 19, Got 21
I bought one for my parents a while back and it sounded very lively and respectable for the money. If I had a bigger budget, I'd recommend the Debut I, which I'm running through a Rotel RQ-970BX phono stage. Sounds stunning to these ears.
Sources: Sony RCD-W100 / MDS-JB980 / RDR-HXD560, Denon TU-1800, Pro-Ject Debut II, iPod Classic 160GB/Onkyo DS-A2X Dock Amps: Onkyo TX-SR606, Rega Fono Mini Speakers: Mission m70
