AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 22-03-2006, 2:27 PM   #1 (permalink)
Wall mounted CD player
Can anyone recomend a wall mounted CD player, preferrably one that holds more than 1 CD at any one time, budget of under £300
Many thanks
Dan
Dan Johnston is offline
Old 23-03-2006, 9:01 AM   #2 (permalink)
Beobloke's Avatar
Thanks: Gave 3, Got 46
I was going to suggest this -
http://www.beoworld.co.uk/beosound9000.htm
.............but then got to the bit about "under £300", so forget that!!
Don't believe anyone who tells you nothing rhymes with orange. It doesn't.
Beobloke is offline
Old 23-03-2006, 11:28 AM   #3 (permalink)
Cable Monkey's Avatar
Thanks: Gave 13, Got 214
Your problem is one of quality. Few companies make this sort of lifestyle product and my observations see them jumping from the very cheap all in ones on the shelves at Curries to the very expensive all in ones on Bang and Olufsens web pages with nothing in between. I think you may have a difficult time finding what you need...
Denon DVD-3910, Denon DVR-3805, Hitachi 32pd5200, 3x Castle Compact LCR's 2x Castle surrounds, Compact Sub
Denon DVD2900, Benchmark DAC1, Cambridge Audio 840A, ProAc Response 1SC
My personal opinions are not those of the AV Forums or any other related website.
Cable Monkey is offline
mounted, player, wall
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
