AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 18-03-2006, 11:45 PM   #1 (permalink)
Thanks: Gave 5, Got 1
Servicing for Marantz CD63 KI-SIG
Can anybody recommend a service agent for an old CD63 KI-SIG. I probably need to have the transport replaced. I love this player and don't want to buy a new one!. I am planning to "hot rod" it like Drew with the Audicomm upgrades (no, not the £1000+ ones ) so that I don't upset the balance of my system that I am quite happy with otherwise.
Thanks everyone!
mike_campbell is offline
Old 20-03-2006, 6:16 PM   #2 (permalink)
karkus30's Avatar
Thanks: Gave 42, Got 103
Thanks everyone!
I had my Marantz modified by a guy called Magnus Obrien down in London, he is not a dealer and just works from home. If you look at my photos on the previous thread regarding superclocks you can see his work. Im not saying that he is the 'best' or anything like that, but as it does not appear you have an answer you may as well see if he will sort out a service. Give him a ring on07944024795 and he does not charge the earth.
karkus30 is offline
Old 22-03-2006, 4:35 PM   #3 (permalink)
BRAVURA's Avatar
Thanks: Gave 0, Got 21
CD63 Laser
Hi Mike.
Heres a step by step guide for replacing the laser mech on a cd63
http://iangclark.net/projects/CD63/CD63.html
You can buy the laser mech from www.grandata.co.uk for £16+vat+ship.
Search their catalog for cdm12.
Cheers,
Mags.
BRAVURA is offline
Old 22-03-2006, 5:16 PM   #4 (permalink)
goatywoaty's Avatar
Thanks: Gave 40, Got 32
Hi Mags,
You seem to know a lot about Marantz stuff so i'd though I would ask you, do you know where I would be able to get a display for the same cd player? and how easy it would be to replace?
Thanks in advance,
Kiran
goatywoaty is offline
Old 23-03-2006, 10:02 AM   #5 (permalink)
BRAVURA's Avatar
Marantz CD63 display
H Kiran.
Whats the problem with the display? Has the player been modded or opened up for any reason? There could be another reason for it not working.
The display PCB is only available from Marantz but I have a couple spare if you need one
The display PCB is easy to fit. You have to remove the lid and front plate of the player, to remove the lid it's just 6 screws 2 each side and 2 at the back. To remove the front plate you have to remove the 2 screws on the top connecting it to the chassis (you will see them when you remove the lid) and take off the trim from the transport mech (there are 2 clips under the tray), you will also see 2 clips holding the front plate to the chassis on the sides unclip these and pull the top it of the front plate forward, give it a bit of a wiggle and it will come free. You also need to disconnect the head phone cable and the ribbon cable from the main PCB. I think there are then 7 screws and a couple of clips holding the display PCB to the front plate just remove these fit the new PCB and reassemble.
Cheers,
Mags.
BRAVURA is offline
goatywoaty (23-03-2006)
Old 23-03-2006, 8:53 PM   #6 (permalink)
karkus30's Avatar
Originally Posted by BRAVURA
Cheers,
Mags.
Magnus ???
karkus30 is offline
Old 24-03-2006, 9:21 PM   #7 (permalink)
Thanks for the lead on this
Mike Campbell
Old 24-03-2006, 9:24 PM   #8 (permalink)
Cheers everyone for the replies to my question especially to Bravura for the link to replacing the laser mechanisim - looks reasonably straightforward too
Mike Campbell
cd63, kisig, marantz, servicing
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
