AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 14-03-2006, 4:23 PM   #1 (permalink)
Thanks: Gave 1, Got 2
Amp/Preamp/Integrated Amp for Totem Forest
I am thinking to get Musical Fidelity A5 amp and preamp or Plinius 9200 Integrated amp, but I would like to have more idea before making any decision.
Thanks for your help.
haimoc is offline
Old 14-03-2006, 6:48 PM   #2 (permalink)
Mentally's Avatar
Thanks: Gave 0, Got 9
Did you hear these amp with these speakers? Have you heard other amps?
Speakers: Jm Lab Chorus S 726. Power Amp: NAD Monitor Series 2400. Pre Amp: NAD Monitor Series 1300. CD Player: Denon DCD 485. Cables: Audio Quest.
Mentally is offline
Old 14-03-2006, 6:57 PM   #3 (permalink)
Yes, I listened to the speakers with MF5 and Plinius at the dealer. I tend to lean toward the MF better than the Plinius.
I would like to know more available options.
Thanks.
Totem Acoustics Forest, Sony SCD-1 Player, Plinius M8 Preamp, & Plinius SA-102 Class-A Amp.
ProAc Response 1.5, Arcam FMJ33 CD Player, Dodd Reference Tube Preamp, & Dodd 50W Tube Amp.
haimoc is offline
Old 15-03-2006, 7:01 PM   #4 (permalink)
Thanks: Gave 1, Got 6
Totems suck juice,I would try the Rega Pre/powers myself,wouldn't touch MF personally.I use my Totems with bel Canto,that will give you a good sound too.
SKA.face is offline
Old 16-03-2006, 11:19 PM   #5 (permalink)
Thanks, SKA.face.
I will look into the Rega option as well. How do you like Bel Canto with Forest? Does the model eVo 2 has enough power to make the Forest sing?
haimoc is offline
Old 17-03-2006, 9:58 AM   #6 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 146, Got 501
Since you're in the US,have a look at the Krell KAV400i which is IMHO superior to the Plinius,as well as more powerful if I remember,and may well be cheaper over there too.
The 400i would give you the power and current delivery that these speakers require,and excellent sound quality.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline
Old 17-03-2006, 4:31 PM   #7 (permalink)
Thanks, SKA.face.
I actually use model1 sigs.Bel Canto have some new power amps out ICE,which are cheaper and smaller than the old range by some margin.Well worth trying.
SKA.face is offline
Old 23-03-2006, 12:19 AM   #8 (permalink)
Thanks: Gave 3, Got 17
Given your locale there is an obvious choice, the new Bryston B100-SST. It's essentially a 3B power amp in one box with a BP-25 pre amp. It's lightning fast, has stunning build quality, great imaging, has enough current to drive a pair of Martin Logan electrostatics and is warrantied for 20 years. If your looking for a completely honest, high power, dependable amp then this is what you need to be looking at.
Best wishes,
Dave
analogueaddict is offline
amp, forest, totem
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
