| AVForums.com is the UK's biggest & best home consumer electronics discussion resource | New to AVForums.com? Start by reading our introduction here. |
#1 (permalink) |
Posts: n/a
Denon POA T10 Amp + Tannoy Fusion 3's
Im putting together a hifi system. Planning on coupling a "Denon POA T10 Power Amplifier" and Tannoy Fusion 3 floorstanding speakers.
Dont know too much about about this kind of stuff...What do you think? Specs.... (Amp) ![]() (Speakers) PERFORMANCE Recommended amplifier power 10 -100 Watts RMS Continuous power handling 70 Watts RMS Peak output power 140 Watts Low frequency response 32Hz Sensitivity 89dB Nominal impedance 8ohms Frequency response 35Hz - 20kHz DRIVE UNITS High frequency 25mm(1") Nitro-Urethane layer damped woven polyester dome, shielded neodymium magnet assembly Low frequency 165mm (6.5") coated multi-fibre paper pulp cone CROSSOVER Frequency 2.7kHz (Bi-wireable) Type 4th order acoustic linkwitz-riley Will this sound good? A fast response would be great. Thanks. |
| Bookmarks |
| Tags |
| amp, denon, fusion, poa, t10, tannoy |
| Thread Tools | |
| Display Modes | |
Global Gold Web Hosting |
