AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 09-03-2006, 9:11 PM   #1 (permalink)
Thanks: Gave 5, Got 16
Speaker Stands vs. Cables
In your opinion, which makes the greatest difference to a system using no stands and standard cables?
Just i've got some reasonable stands, cost about £120 and i didn't notice much difference (slightly better bass) and am wondering if i will get a bigger or smaller upgrade from cables?
Ben
BenW is offline
Old 09-03-2006, 9:39 PM   #2 (permalink)
Thanks: Gave 1, Got 6
In my experience, much smaller improvements/changes are noticed from cable upgrades. Moving speakers around can and often does have a huge impact on the sound.
Rotel RA-01, B&W DM602, NAD C521BEE
Dr.EM is offline
Old 09-03-2006, 11:02 PM   #3 (permalink)
karkus30's Avatar
Thanks: Gave 42, Got 103
Thats a really tough question to answer. I would say that they make similar amounts of difference in general, but spend £1000 on special cable that isnt suitable for your system and it might really destroy any cohesion you have built up, however spending serious amounts on stands will rarely have an adverse effect even if it doesnt improve the sound.
You could of course spend a couple of quid on some blue tack to secure (called coupling in hifi terms) the speakers to the stands (small bits, not big wodges), this can have as dramatic effect as cable or stands, but costs virtually nothing.
karkus30 is offline
Old 09-03-2006, 11:31 PM   #4 (permalink)
Thanks, my stands have some small bluntish spikes on the top plate as well as bottom and i've also put some bluetak in the middle to secure the speaker
If the difference is going to be less/similar then i probably won't bother. Only reason would be to make the speaker cables look better
BenW is offline
Old 13-03-2006, 5:30 PM   #5 (permalink)
Thanks: Gave 9, Got 11
Have you filled your stands with sand ,I put 3kgs in each of my floorstanders this really made a big improvement to the sound.
Regards Martin
tv:sony KDF-E50A12U, DVD Player: Sony dvp-ns92 ,ps3, H.C. Amp: Sony STR-db790, Sky Box : panasonic, Freeview box : Sony VTX800, Speakers:Front : Eltax Liberty 5+, Centre : Eltax liberty, Rear : Eltax Bi-Polars, Subwoofer : Eltax Liberty,
pdbmjb is offline
Old 14-03-2006, 5:45 PM   #6 (permalink)
Yep, 1/2 to 3/4 filled the stands and put more in one than the other due to my room shape.
When i think back to the day i got my stands thats probably about the time my ear problem started (Still to be fully sorted). I noticed a very minor change when sand filling.
Anyway, i got a 5m mains cable (£26 inc from ebay) today to replace my daisy chain of extension cables which also run along my speaker cables. I'm yet to recieve my male IEC so i can plug it in but i'm hoping for an improvement.
BenW is offline
Old 14-03-2006, 7:24 PM   #7 (permalink)
Thanks: Gave 686, Got 813
Room acoustic dominate how things sound, in this respect speaker stands are 'part of' that equation. Cables are WELL down the list.
Do everything with excess, even excess
Nic Rhodes is offline
Old 15-03-2006, 12:59 PM   #8 (permalink)
Drew2's Avatar
Thanks: Gave 38, Got 37
Also make sure your sand is kiln dried - a quick blast in the microwave (before it turns to glass!) has the same effect. You want zero moisture content.
Other than that; sitting your stands on concrete or if you can afford it marble slabs can help 'strengthen' the sound.
As for speaker cable - haven't done a full test on my system yet but CAT 6 LAN cable could be the way to go, and you get some real cool colours! You need 3 lengths braided per speaker, very promising and very cheap compared to Kimber!
"When free speech is censored, I have to ask what is the meaning of FORUM?"
YEAR of the Mouse - soon
Drew2 is offline
Old 15-03-2006, 6:59 PM   #9 (permalink)
Why is it that sand must be 'kilm dried'? I gave mine a toast in the oven before putting in the supplied plastic bags in the stands.
How exactly can i improve my room acoustics? I haven't got curtains in there ATM but they'll be going in soon and its a bedroom so i've got a thick matress and duvet/linen
BenW is offline
cables, speaker, stands
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
