Matching System with Speakers - Advice Req'd
Old 27-01-2006, 8:37 PM   #1
*Matt*
Posts: n/a
Hopefully some of the more knowledgeable members can comment on the following System/Speaker match-up (I'm on a very tight budget!!!)
System: Yamaha CRX-M170
http://reviews.cnet.co.uk/digitalrad...94805-1,00.htm
Speakers: Mission m73
http://www.hifichoice.co.uk/review_print.asp?ID=1198
I have already purchased the m73's from another member on this board and due to a tight budget and lack of space I would like to add the Yamaha to them.
Should I be concerned that the Yamaha has a 50w amp and the speakers are 100w? Will the sound quality be ok?
Last question would be to ask for recommendations for decent/budget speaker wire.
Matt
Old 27-01-2006, 8:48 PM   #2
Thanks: Gave 22, Got 17
What is your budget?
The different outputs should't matter that much I would't think
edit: have you thought about the teac or denon in that price range or even going second hand?
Old 27-01-2006, 9:06 PM   #3
*Matt*
Posts: n/a
Spent a bundle furnishing my new flat so probably can't go more than £200 for the micro-system.
Choose the Yamaha as it will fit in the available space is £40/60 cheaper than the equivalent Denon and has good reviews.
Old 28-01-2006, 12:27 AM   #4
Thanks: Gave 15, Got 10
the missions aren't too hard to drive iirc - unless you like v high volumes, the yamaha should be fine (at least in terms of volume/power - haven't heard it so don't know what the quality's like).
If you don't need DAB/CD (perhaps you could use your DVD as a source, and a freeview box for digital radio?) you could v likely get a better amp than the yamaha if you were just buying an amp...but you may want the convenience of a mini-system
Jon
Old 28-01-2006, 12:50 AM   #5
*Matt*
Posts: n/a
Jon
Cheers for the info. I would prefer all seperates but at this time the mini-system is going to be more convenient.
Anyone care to recommend speaker cable ( 2 x 1.5m required)?
Old 28-01-2006, 12:02 PM   #6
esp if you're on a budget, I'd suggest you just get a decent thickness, well-insulated copper speaker cable - shouldn't be much more than £1/m. I use gale 189 from richer sounds (I did try more expensive cable, but couldn't hear any change so sold it ) but Maplin and most similar stores will do something along these lines...
Jon
