You have several options, as you are already aware.
1.) upgraded to a quality internal Sound Card and use the analog outputs. But, I would advice forgetting a multi-channel surround sound card, and focus on studio grade Stereo Sound Cards. M-Audio makes a few. Many of these are used in Home Recording Studios.
This is pure analog. The DACs on the sound card convert analog and send the signal directly to your amps. Some will say that environment internal to the computer is too noisy for an analog signal. I don't doubt that this noise exists but I think it is greatly exaggerated. Again, most home recording studios are recording directly to multi-channel STEREO sound cards. In this case, multi-channel means mutiple stereo channels.
2.) An external DAC, such as the rDAC. Keep in mind the OUTPUT of a DAC like this is stereo. There is no need for a multi-channel surround sound card if you are limited to Stereo out.
In this case, the output is DIGITAL to the external DAC. Since Digital is pretty much immune to noise, this assures a clear sound on the output of the DAC.
Of course, there are several options for Digital Out - USB, Optical, and Coaxial. You must make sure you sound card has the feature you intend to use. USB for standard CD quality is fine. But only the very newest USB interfaces are capable of sound quality ABOVE CD. Even then, most are limited to 24b/96k, which is still pretty good.
However, I would speculate that the Optical and Coaxial outputs, in general, should have near unlimited HiDef quality. You should be able to go to 24b/192k, which is about the highest you will find.
That said, you want to check the specification on your outputs and inputs to determine any limitations on them.
If you don't have or plan to have audio files in better than CD quality, then the USB interface will be fine. Virtually all USB interface are capable of 16b/44.1k.
Keep in mind, if you rip a standard 16b/44.1 CD to 24b/192k you've gained nothing. The RIP process can't add data, you will simply create an extremely large 16b/44.1k file. HiDef audio must originate in that HD format. If you rip music from a BluRay, then you have true HiDef. If you download music from HiDef sites, then you have true HiDef. So, sources of true HiDef are rare at this point, but this is an expanding market.
As to External DACs, you can get a specifically USB-only external sound card or DAC. Or, as you've already suggested, you can get a more versatile external DAC like the rDAC which is not limited to USB. Likely you can save a bit on a USB-only external DAC, but they can also be fairly expensive.
So, you need to look at the short term and the long term. HiDef audio is on the way, and it is certainly the future, but it is the somewhat distant future. I don't see it become mainstream for several years. You must also consider your sources of music. If they are not true HiDef, then USB is probably fine.
Again, it doesn't do any good for the external DAC to be HiDef ready if the source sending the signal is not capable of sending HiDef Data, so it is important that you look at and understand the specs of the source of that sound data. If you sound card or computer digital outs are not capable, then the external DACs capabilities are wasted.
As to which is the best method, I'm not sure there is one. There is only the method that best suits your needs and budget.
Personally, I would say get a DAC that has higher definition capabilities, at least 24b/96k on the USB port. But you must also make sure your source has that same capability. Unless I'm mistaken, USB 3.0 has just been released, and it has extreme data speed capability, near that of Ethernet computer networks. But, for audio, the more common USB 2.0 is more than enough. However, many external DACs have only implemented USB 1.0 on the assumption that for CD quality, that is enough, and they are right, for CD quality USB 1.0 is enough ... for now.
So verify the capabilities of your sound card data outs, and your computer USB ports, though I can't imagine you computer not having at least USB 2.0.
Then pick an external DAC that has a HiDef USB port. Though Coaxial or Optical would eliminate any data rate or HiDef problems.
Lastly, don't discount a Studio Quality Sound Card with analog outputs. That is probably the lowest cost route to good sound.
So, a lot of factors to consider, and there really is no one right perfect answer, they are all good options.
Personally, I would be torn between a good internal Studio Quality Stereo sound card, and a good external general purpose DAC. The external DAC is the most versatile and probably the best ultimate sound quality, but also the most expensive, and it is probably the route that a majority of people would take.
Just a few thoughts.
Steve/bluewizard
