Originally Posted by 5teviewonders Thanks for the warm welcome mykyll2727. Like MI55ION said, i'm playing audio from my sound card to my receiver. I'm planning on using Van Damme cable for the interconnects so i thought perhaps the soft splitters as shown in the picture above would completely remove the advantage of using quality cable. |
Yeah, I can understand that. It's why I personally chose to go with the hard. There are a few fine cable makers that make soft splitters from their own designs. My reasoning, valid or not, was that to ensure the best sound I'd need to use products from the same maker and of the same design if I went that route. Also that route can be more expensive. Not saying I'm right in my thinking it was just my logic path.
My suggestion would be to decide which design, hard or soft, you feel suits you best and then start off with the least expensive option. That way you can hear if your SQ is compromised. If not then you're good to go. If it is, well at least you're not out much $ and then you can look at other options. Even if it does decrease your SQ at least now you know it matters. If you go the most expensive route and there's no negative effect you'll never really know if it mattered or not and if you could've saved some $. That is of course that price matters to you. If cost is of no consequence well then go for the best you can find. If it still adversely affects the sound well at least you know you did your best.
BTW I'm not that familiar with Van Damme cables. Do they make a soft splitter in the version you need?
