Originally Posted by Tone-uk What do your blind test comparisons tell you about, say, cd players, dacs etc? Are the differences audible? If so, are they easily detectable of difficult? |
There are lots of variables but in some cases I've found a perceivable difference between solutions and how easy or hard can depend on the solution.
Differences may be analogues to "spot the difference" pictures. Some times it's pretty obvious and sometimes it takes more time to work out what's different. A casual glance may suggest the pictures are the same when in fact they aren't.
I've found preconception is a powerful influence and I'd prefer not to fool myself if possible. The assessment I do are to satisfy my own interest not reviewing or telling others what they should or shouldn't perceive or prefer.
Originally Posted by Tone-uk Also, do you think the differences are greater than that of, say, speakers and will they contribute a great deal to the sound.? How about room acoustics - do you feel the differences that may or may not be there bewtween cd players will be swamped by a room (unless the room is good). |
Lots of variable but I think generally the speaker and room will typically have a more significant impact on the overall performance. A poor room, setup and/or speakers may mask other differences.
Originally Posted by Tone-uk Finally, do you find my views extreme? I must point out that they are based on the findings of many people far more qualified than myself. People like JJ Johnston, chief scientist at DTS, Alan Shaw of Harbeth etc etc. |
I've also read lots over the years from AES and many other sources including JJ in the audio myths workshop etc.
Don't take this the wrong way but I have no opinion or interest in your views. I'm only really interested in what I perceive in my system and attempt as much as possible to minimise factors that will influence what I "think" I hear.
Avi
