can you connect an active sub to any stereo amp?
Old 27-12-2010, 1:27 AM   #1
maxflinn's Avatar
Thanks: Gave 66, Got 30
i have an acoustic energy radience sub, which has an av sub input (standard sub cable) and line inputs..
i've currently got the sub connected to my yamaha as-500 via the yams sub out and the subs av in connection using a standard sub cable, it works fine..
however, i was thinking of buying a marantz pm7000 (no plans to lose the as-500, but wouldn't mind a second amp), the pm7000 doesn't have a sub out though, is there any way i could still connect it to the sub?
cheers..
Old 27-12-2010, 5:26 PM   #2
Don Dadda's Avatar
Thanks: Gave 93, Got 356
Hi and Merry Christmas
If the sub has a High Level Input connection then it can with any or most stereo amps via the speaker bindings
maxflinn (27-12-2010)
Old 27-12-2010, 5:57 PM   #3
maxflinn's Avatar
hi and merry xmas to you don dadda
thanks for that, i had an idea that it could be done but wanted clarification, much obliged
Old 27-12-2010, 6:13 PM   #4
Don Dadda's Avatar
No probs.
EDIT: The link below is for a BK Xls200 sub and on page 3 it shows you how to connect to a stereo amp which is i think is standard for most subs except the sub's HFE input connector, which i understand could be different on the AE.
http://www.bkelec.com/hifi/Sub_Woofe...2%20MANUAL.pdf
Old 27-12-2010, 8:56 PM   #5
maxflinn's Avatar
thanks again dd
