I was looking on the forums the last couple of days for info on this system, no-one seems to be posting much about it (it's not long out). I bit the bullet today and bought one (first "proper" hifi system), and so far I'm very impressed.
Sound quality is great from CD's and the iPod integration is excellent (no dock needed, unlike the previous model). I thought it was useless to begin with, as the remote controlled what was on the iPod screen, in a pretty useless manner (strange menu depth problems). Then I hit the Remote/Browse key on the remote and this allows access to menus on the display screen of the hi-fi, and is easy to see and use. Scrolling track and artist names are cool.
The DAB tuner gets much better reception than my previous DAB set, and has a much better depth of sound (I mostly listen to radio 4 and such).
Sound quality is much better than the iPod connected to AUX, as the on-board DAC's are used instead of the iPod, In all I am very pleased with it so far.
Here's the setup :
To help anyone else that was looking into this model, I can answer any questions anyone has.
