Originally Posted by jpr141 Has anyone compared the denon f107 to the denon dm37 , if you have how much did the f107 out perform and sound beter than the dm37. If indeed it did sound better. Also people even if you havent comapred do you think there will be much diffence between them. |
I was looking in to this myself before I decided to go for a different solution to my needs.
They are good at each price point. There is the expected improvement with the extra outlay in cost.
I have been unable to do a direct comparison whereby the DM 37 and the Denon F107 were in the same room, that would have been a better comparison.
At the F107 price and when you add on a good pair of speakers, probably MA BR2 , Diamond 10.1 or something equivalent rather than the Tannoy F1 which would be good for the DM37 but a bit under par for the F107 the cost soon becomes close to enty level seperates.
If space is an issue than the F107 delivers the goods in a small package!
Hope that helps a little bit.
P.S. Just saw you have the DM 37, if you are happy with them and the F107 isn't going to be your main system probably not worth investing the extra cash?
