Stereo Amp with pre amp inputs
Old 21-11-2009, 11:10 PM   #1
1,676, Level: 9
Points: 1,676, Level: 9 Points: 1,676, Level: 9 Points: 1,676, Level: 9
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 51, Got 0
Where can I view/ find. these type of amps,
I am thinking connecting my Onkyo Txnr905 av receiver to a stereo amp, via pre amp output / inputs, and would like to view a list of these, marantz, Cyrus, Roksan etc
Old 22-11-2009, 1:15 AM   #2
3,057, Level: 13
Points: 3,057, Level: 13 Points: 3,057, Level: 13 Points: 3,057, Level: 13
Thanks: Gave 7, Got 156
??? all stereo amps have line level inputs designed to be run from a pre-amp. That is what amps are for!
Is there something that you don't understand or is the terminology confusing you?
Largepat (25-11-2009)
Old 22-11-2009, 7:31 AM   #3
3,228, Level: 13
Points: 3,228, Level: 13 Points: 3,228, Level: 13 Points: 3,228, Level: 13
Thanks: Gave 11, Got 16
You need a stereo amp with power amp inputs. If you are after integrated amps then the Audiolab 8000S can be switched between pre and power amp operation while the
The Kandy K2 would need no switching.
There are probably more integrated amps out there towards the higher end which also will, so be on the lookout for power amp in connections.
Old 22-11-2009, 7:59 AM   #4
BlueWizard's Avatar
25,669, Level: 39
Points: 25,669, Level: 39 Points: 25,669, Level: 39 Points: 25,669, Level: 39
Activity: 76.9%
Activity: 76.9% Activity: 76.9% Activity: 76.9%
Thanks: Gave 11, Got 1,951
A lot of integrated amps have jumpers between the pre-amp output and the power amp inputs. So, you can get at just the power section by removing the jumper and plugging straight into the power amp.
Notice the back of this NAD amp, has both a jumper between one pre-amp out and the power amp ins, and a separate pre-amp out to drive things like subwoofers. The Power Amp input are labeled MAIN.
http://nadelectronics.com/img/resamp...-C355_rear.jpg
Now, if you don't need to use the stereo power amp as a stand alone stereo, the indeed a power amp is OK. But, if you plan to run the stereo without the AV amp when playing music, then you are going to need an integrated amp, and you will need to use the standard Line In (AUX, TAPE, CD, DVD, etc...) inputs.
It is really just a matter of deciding if you need just power, or if you need an integrated amp. Then, look at amps that you like, and see if they have this break between the pre- and power section. Of course, with purely power amps, this isn't a concern.
Steve/bluewizard
Bibby_83 (22-11-2009), Largepat (25-11-2009)
Old 22-11-2009, 10:25 AM   #5
trailer's Avatar
14,467, Level: 29
Points: 14,467, Level: 29 Points: 14,467, Level: 29 Points: 14,467, Level: 29
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 165, Got 233
You might be meaning amps with have the unity gain feature which is an input designed for this purpose.
Naim amps for instance have an input labelled "AV" which when used bypasses the volume controls of the integrated and in effect turns the stereo integrated into a pwer amp.
Powered by
 Latest popular product prices
ION Profile LP USB
3 prices from
 £54.97 Click to show/hide the offers
ION Profile Express USB
1 price
ION Profile LP USB
3 prices from
1 price
ION Profile LP USB
3 prices from
1 price
TEAC CD-P1260 Black
1 price
 £129.34 Click to show/hide the offers
TEAC CD-P1260 Black
1 price
 Updated February 8th at 3:30am. Prices include delivery.
