Hi guys,
I am pretty much sold on going the digital streaming route, as I love controlling my music from my laptop. I have heard only good things about the Linn DS range (although I would also consider the Logitech Transporter) and I think that my choice of source is pretty much done..
Now, as for speakers, I like the Monitor Audio range, having heard the lower silver range, and the GS60 come highly recommended.
I need to go to some shops and demo as much as possible (I'm stuck on a rock - Jersey - at the moment) and make sure these are the speakers for me. Aesthetics are important to me, and the GS60s tick the right boxes in the looks department.
These speakers cost about £2k.
Does anyone have experience with the speakers, and more importantly are there any particular amps that would be worth a demo in unison? Recommended amp requirements is 60 - 200 Watts - I'm not sure if that means per speaker, or in total? I'm fairly certain it means in total, for both speakers.
My understanding of the Linn DS range/Transporter, is they will work pretty well with any good amp/speaker combination, and the synergy of amp and speakers are what is most important.
The GS60s appeal to me because apparently they are very adept at the kind of fast paced, punchy music I like, as well as modern rock, dance, electronic etc - I don't really listen to classical music..
So, I know I might sound crazy having practically made up my mind on source and speakers without any demos, and it may be that the GS60s aren't to my taste after all. After research though, I have a feeling they will pretty damn good for me...
So... what kind of amplification should I be looking at....?
I take it I'm gonna need to blow at least £1k on an amp to drive these puppies - I've got no problem spending £2k to be honest. Been saving up for ages and now it's time to get that stereo I've always dreamed of.
The problem with a Linn DS or similar streaming device, is you can't really take it into a shop, because there's no music stored inside the DS, and you can't plug in a CD either... I doubt most Hi Fi shops have a wifi connection...
So, what amps should I look to demo with the GS60s? Will I probs end up going pre/power or integrated?
Many thanks!
Keyser
