AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Audio Electronics > Hi Fi Systems and Separates
LinkBack Thread Tools Display Modes
Old 11-01-2004, 8:58 PM   #1 (permalink)
beaspoke
Posts: n/a
Harmon Kardon Amp
Can anyone help? I have an old Harmon Kardon PM665 amp which is faulty but repairable - possibly £50 - £70 to resolve. Question is it worth while fixing or should I go for a replacement new amp of an equivalent spec? Ideas?
Old 11-01-2004, 9:07 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,093
well you dont get much amp for £50-70 ?Current HK range are £250+ If this helps.
hornydragon is offline
Old 11-01-2004, 9:13 PM   #3 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 146, Got 501
as horny says,for that sort of money,repairing the amp would seem the best idea,unless you want to spend at least twice that amount on a new budget amp.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline
Old 11-01-2004, 9:18 PM   #4 (permalink)
overkill's Avatar
Thanks: Gave 228, Got 539
Weeeeeeeeeeeeeell!! Thats a tricky one!! The 665 cost around £620-699 new and while not "state of the art" was pretty hefty at 90 watts per channel RMS. If you spent that now you would see massive differences/improvements!!! However, £70's not much considering the intial outlay (if you bought it new?) and it should go for a while yet afterwards.
So, you have to decide whether it's the right time for an upgrade, and with the improvements in tech over the last 15 years quite a hefty one at that. If the rest of the system is of a similair vintage you will see improvements but not as much as if you went whole hog and upgraded the lot!! You could also use a new amp as a basis for a rolling upgrade as money becomes available.
Were it me, i'd go for a new amp, but that's just me. It's your budget, and really, only you know if it's the right time.
"Someone recently said to me, there's a lot of nutters out there" "Then i saw the ABD website and realised they were right!!!"
"Yes, he's back, i've no idea why, and nobody cares anyway........."
overkill is offline
Old 12-01-2004, 7:08 PM   #5 (permalink)
beaspoke
Posts: n/a
Thanks for the replies which should help me decide but I also need a decent upgrade path for my aging Yamaha CDX550E and Mordaunt Short HT30 speakers. I'm looking for some floorstanding speakers possibly the Mission M731i, Mordaunt Short 904 or the Gale 3030 - Richer sounds specials. No idea what direction to take for the CD, I’m really liking the Cambridge Audio Azur 540C. Views/comments??
amp, harmon, kardon
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
